Home > In Car Electronics > Locked out 2006 RRS Urgently need to gain entry
CRACKA
Australia 2006 Range Rover Sport Supercharged Bonatti Grey
MY RRS is not responding to either of the 2 key fobs I have. Do not think its a flat car battery. Tried the passengers door secret key ,it does not turn enough to open it (it has before).
Any ideas ????? or another way to gain entry ?? Its Sunday here but I need the RRS urgently. 2006 4.2 S/C with Tow Pack, Side Steps, DRL's, 19" & 20" wheels, additional 110 ltr Fuel Tank Roof Rack and performance mods.
1952 Rover 75 (Cyclops) First Car !!! Fond memories -was restored-good for 93mph.
Post #607878 Sat Dec 26 2020 9:49pm
Stevepd
You could try the 3rd button on both keys (the LR print). Hopefully it’s pre-programmed to open the tailgate........ 2006 2.7 TDV6 HSE in Cairns Blue.
Post #607880 Sat Dec 26 2020 10:12pm
Oil in the lock
Wait and try again
Post #607884 Sat Dec 26 2020 11:49pm
Have you tried pushing on the door on passengers side door or thumping by the lock/catch as you try to unlock it, just in case it's a bit stuck due to lack of use, only a suggestion.
Post #607886 Sun Dec 27 2020 12:18am
CRACKA
Thanks for the replies. I got in the passenger door key lock it was stuck. It appears that the fobs do not open the car when its ' superlocked' . Is there a way to overcome this??? Programming ??? 2006 4.2 S/C with Tow Pack, Side Steps, DRL's, 19" & 20" wheels, additional 110 ltr Fuel Tank Roof Rack and performance mods.
Post #607887 Sun Dec 27 2020 5:34am
garrycol
Australia
The serviceable fobs will always unlock - even if super locked - try unlock and then unklock again.
I am not understanding why you cannot open the passenger door with the key - particularly if the lock is lubricated as we do not suffer the corrosion that other countries do.
Is the main battery in the car flat? Do you have a genuine towing loom fitted as you can power the battery through one of the connectors - not sure which one. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #607890 Sun Dec 27 2020 6:47am
Oldandconfused
It's the white socket, 13 pin I think, I use one of these with my CTEK;
https://www.disco3.co.uk/shop/tow-electric...-p45.html.
I don't know how to charge it without.
Post #607892 Sun Dec 27 2020 8:08am
