Home > General > Rear passenger door lock
Nbrit1
Hopefully someone can help. 2011 RRS
The rear passenger door won’t open unless it’s the first door opened off the central locking. If I open any door first from locked it won’t open, also if it’s the first door I open off the central locking and close it, it won’t open again unless I central lock the car and unlock again. Not the biggest issue, but massively annoying.
Post #607743 Tue Dec 22 2020 12:30am
Very similar issue I had with my O/S/R, strong possibility you will need a new Latch/Lock Assy. not a uncommon issue.
Post #607744 Tue Dec 22 2020 1:14am
Smarttech
Had this with my 2012 L320 sport. The door locks seem to lose the strength to unlock the door as they get older and it seems to be the door you use least. You will need to replace the lock mechanism in the door.. 2017 SVR. SVO Scafell grey Ebony interior
2012 3.0 SDV6 Autobiography santorini black with ebony/cirrus interior. Gone
Post #607748 Tue Dec 22 2020 8:21am
Leechicken74
As Col says it’s very likely to be your door mechanism as I had a very similar issue with the lock behaving very randomly, so I am in the process of changing my actuator, just waiting for the correct part to arrive now after buying a unit on fleabay to find it wasn’t the correct one! So best advice I can give you is to make sure you know what part you want before you spend an hour or so stripping the door to remove the old unit Thumbs Up Lee
3.6 TDV8 2010 (facelift) HSE Stornaway Grey
3.0 TD6 2018 Discovery HSE Luxury Indus Silver Dynamic Packs 1 & 2 - Sold due to COVID budget cuts at home 😢
Mini Countryman 2.0 Cooper SD All4 - White, black wheels, black decals - Great little car and so much fun!
Post #607754 Tue Dec 22 2020 11:27am
Devon Z
England 2005 Range Rover Sport TDV6 HSE Java Black
Mine was not locking occasionally, replaced it with a S/H unit which now sometimes doesn’t unlock unless I press unlock button a second time Sad
Joys of RRS ownership Confused Steve
2005 2.7 TDV6 HSE, ongoing project.
1998 Volvo V70 R auto FWD, mothballed future project.
1999 BMW Z3 (owned from new) garage queen.
Post #607757 Tue Dec 22 2020 11:40am
Tony666
2005 Range Rover Sport TDV6 HSE Bonatti Grey
As others have said, likely new mechanism needed. Due to the hassle of replacing I wouldn’t bother with a cheap copy, get the LR one. I’ve had to replace 3 of mine on my 2005......and don’t leave it, it’ll get to a stage where it becomes almost impossible to open, and you’ll have great difficulty opening the door to replace the actuator, which may result in lots of swearing and a dremmel!!🤦‍♂️
Post #607860 Fri Dec 25 2020 7:55am
Devon Z
Cheers Tony Very Happy Steve
Post #607866 Fri Dec 25 2020 1:02pm
