Home > General > Rear passenger door lock |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4968 |
Very similar issue I had with my O/S/R, strong possibility you will need a new Latch/Lock Assy. not a uncommon issue.
Tue Dec 22 2020 1:14am |
Smarttech Member Since: 11 Jan 2017 Location: West Sussex Posts: 424 |
Had this with my 2012 L320 sport. The door locks seem to lose the strength to unlock the door as they get older and it seems to be the door you use least. You will need to replace the lock mechanism in the door.. 2017 SVR. SVO Scafell grey Ebony interior
Tue Dec 22 2020 8:21am |
Leechicken74 Member Since: 09 Nov 2020 Location: Kent Posts: 59 |
As Col says it’s very likely to be your door mechanism as I had a very similar issue with the lock behaving very randomly, so I am in the process of changing my actuator, just waiting for the correct part to arrive now after buying a unit on fleabay to find it wasn’t the correct one! So best advice I can give you is to make sure you know what part you want before you spend an hour or so stripping the door to remove the old unit Lee
Tue Dec 22 2020 11:27am |
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 314 |
Mine was not locking occasionally, replaced it with a S/H unit which now sometimes doesn’t unlock unless I press unlock button a second time
Tue Dec 22 2020 11:40am |
Tony666 Member Since: 26 Jul 2011 Location: Barry Posts: 170 |
As others have said, likely new mechanism needed. Due to the hassle of replacing I wouldn’t bother with a cheap copy, get the LR one. I’ve had to replace 3 of mine on my 2005......and don’t leave it, it’ll get to a stage where it becomes almost impossible to open, and you’ll have great difficulty opening the door to replace the actuator, which may result in lots of swearing and a dremmel!!🤦♂️ |
Fri Dec 25 2020 7:55am |
Cheers Tony Steve
Fri Dec 25 2020 1:02pm |
