Home > Maintenance & Modifications > Ride height sensor
Darranj7777
Wales 2005 Range Rover Sport TDV6 SE Java Black
Ride height sensor
Hi I got a fault with a ride height sensor as soon as I clear the fault on my Hawkeye it comes back, if I fit a new one and clear code with the Hawkeye will it be ok.
Or is it more to it
Post #607729 Mon Dec 21 2020 12:54pm
probably.
unless its a wiring fault. Inspect wiring near sensor
Post #607730 Mon Dec 21 2020 12:58pm
Darranj7777
Ok
Post #607731 Mon Dec 21 2020 12:59pm
If you replace a ride height sensor then you'll need to calibrate the suspension too, don't forget. If not, it'll likely throw a series of wobblies at you. 2012 SDV6 - it's missing a couple of cylinders
Post #607735 Mon Dec 21 2020 2:21pm
Darranj7777
Ok but can I be done off a Hawkeye?
Post #607737 Mon Dec 21 2020 2:25pm
