![]() | Home > Maintenance & Modifications > Ride height sensor |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5040 ![]() ![]() ![]() |
probably.
Darranj7777 Member Since: 11 Nov 2018 Location: Neath Posts: 23 ![]() ![]() ![]() |
Ok |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9058 ![]() ![]() ![]() |
If you replace a ride height sensor then you'll need to calibrate the suspension too, don't forget. If not, it'll likely throw a series of wobblies at you. 2012 SDV6 - it's missing a couple of cylinders
Ok but can I be done off a Hawkeye? |
