Home > General > Tailgate gas struts
Salisburylander
2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Tailgate gas struts
Mine have been really weak and the other day, the tailgate closed whilst I was putting shopping in the boot and much to my wife’s amusement, hit me on the head. I’ve ordered replacements and they should be here today. Are they easy to change?
Post #607108 Mon Nov 30 2020 10:55am
Salisburylander
Turns out my worries were unfounded. I held the tailgate up with a broom, removed the clips on the ends of the struts, a sharp tug on the strut and removed each one. My car has asymmetric struts, so sorting out which one is which takes a second or two, and then a quick reassemble. The struts make the tailgate slightly more difficult to open but after a while, there is a hint of self-opening.
All-in-all, very pleased with it and one of those things I wished I had done sooner.
Post #607114 Mon Nov 30 2020 3:32pm
mgrover
aiye i did mine a while back. super easy to do. would always recommend doing em
Post #607117 Mon Nov 30 2020 7:55pm
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
@Salisburylander. Hi. Where did you get them from out of interest? Barrie.
2017-Jan 2024: 2005 RRS 2.7TDV6. Best car I ever had - until now!
Current: 2018 Ford Ranger Wildtrak 3.2
Post #607129 Tue Dec 01 2020 11:07am
mgrover
you just have to be careful actually since their not the same size, one side is slightly longer than the other
see below
Post #607131 Tue Dec 01 2020 12:27pm
Seatown
Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands
I also did mine earlier this year. I got them from Advanced Factors (see site sponsors). Part numbers were LR027543 RH /LR029320 LH. Around £20 each IIRC. 2010 TDV8 - current - my first RRS, loving it so far......
2005 Cayenne S - handling defied physics and what a sound, so sod the mpg!
1995 Disco TDI- surprisingly reliable, shame about the peeling dash & other trim
Lots of other non 4X4's in between times.........
Post #607161 Wed Dec 02 2020 6:17pm
knwatkins
Are you sure? I thought they were the same size, but the gas pressure is slightly higher in the one side than the other due to the extra mass of the subwoofer on the one side of the tailgate.
Here are my notes from when I replaced mine...
LR029320 - left hand, force of 755 Newtons. (OEM part number 6H32-406A10-BB and has blue writing).
LR027543 - right hand, force of 785 Newtons. (OEM part number 6H32-406A10-AB and has red writing). Kev
Post #607167 Wed Dec 02 2020 10:53pm
mgrover
Actually yeah that was it, the different pressures not lengths woops
Post #607174 Thu Dec 03 2020 8:20am
Seatown
The ones I got from AF were the both the same and are a direct replacement for both the LH and RH LR part numbers. They're upgraded (higher pressure) so will fit either side.
No worries about the slightly higher pressure one on both sides as it's not like the tailgate leaps into the air at the best of times Very Happy 2010 TDV8 - current - my first RRS, loving it so far......
Post #607205 Fri Dec 04 2020 1:11pm
