Home > General > L320 door seals?
Dunc101
L320 door seals?
I have a lot of road noise coming from my front passenger door, - itโ€™s been getting worse over the past 6 month - so I was going to replace both primary and secondary seals to reduce the noise (suspected perished seal(s)). But before I do, are there any aftermarket primary / secondary door seals that block out more noise than the LR / Britpart seals?
If there is a better seal for a quieter cabin, I might then replace all door and tailgate seals. Thanks! Smile
Post #606615 Sat Nov 14 2020 12:08pm
peterjj
Australia
I also have a lot of road noise coming from my front passenger door. I can't help you re the seals but would appreciate if you update this thread on how you go Smile Pete
2008 L320 TDV8
2022 Hilux Rugged-X
Post #606652 Mon Nov 16 2020 2:46am
Stevepd
I have noise from the front passenger seat (snoring). If I took a photo and got found out Iโ€™d be dead Mr. Green 2006 2.7 TDV6 HSE in Cairns Blue.
Post #606661 Mon Nov 16 2020 3:03pm
Dunc101
Stevepd - ๐Ÿ˜‚ Your seals must be really effective! ๐Ÿ˜‰
Post #606677 Mon Nov 16 2020 9:18pm
Dunc101
peterjj - will do. I canโ€™t find any other options, so in lieu of any other suggestions here, Iโ€™ll go for the britpart seals I found on lrparts.net. ๐Ÿ‘๐Ÿป
Post #606678 Mon Nov 16 2020 9:21pm
Dunc101
Update - secondary seals changed. Thats the easy part. Primary seals (unbeknownst to me through lack of research) are stuck, rather well, to the door frame. One removed, and new seal applied. Seal does not stick. Britpart seal returned and refund given. LR seal has now been sent to me - awaiting my time to fit it.
Ill report back once fitted. The Britpart seal may well be ok as a seal, but the adhesive the provide is shockingly bad. FYI.
Post #607990 Wed Dec 30 2020 1:08pm
