![]() | Home > General > L320 door seals? |
Dunc101 Member Since: 16 Nov 2017 Location: Bedfordshire Posts: 32 ![]() ![]() ![]() |
I have a lot of road noise coming from my front passenger door, - itโs been getting worse over the past 6 month - so I was going to replace both primary and secondary seals to reduce the noise (suspected perished seal(s)). But before I do, are there any aftermarket primary / secondary door seals that block out more noise than the LR / Britpart seals?
I have noise from the front passenger seat (snoring). If I took a photo and got found out Iโd be dead |
Stevepd - ๐ Your seals must be really effective! ๐ |
peterjj - will do. I canโt find any other options, so in lieu of any other suggestions here, Iโll go for the britpart seals I found on lrparts.net. ๐๐ป |
Update - secondary seals changed. Thats the easy part. Primary seals (unbeknownst to me through lack of research) are stuck, rather well, to the door frame. One removed, and new seal applied. Seal does not stick. Britpart seal returned and refund given. LR seal has now been sent to me - awaiting my time to fit it.
