Home > Technical > ACE leaking |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 |
i always like to use maltings offroad. they've also been decent to me. also get yourself a few of the ram seals incase you butcher them. i find the oring fine but the small white plastic ring always gets mauled. |
Wed Nov 11 2020 7:57pm |
the_wombat Member Since: 29 Oct 2020 Location: Huntingdon Posts: 64 |
Ive had good experiences of Maltings as well.
Wed Nov 11 2020 10:48pm |
Most of the parts arrived today, so on getting back from work while there was still a bit of light, I managed to get the old rear ACE pipes off (Thanks Disco_Mike, just needed to get the heat shield off to get to that clip 10mm bolt) and the new rear pipes in place.
Fri Nov 13 2020 7:11pm |
New valve block pipe seals still not turned up from DLS. Ordered on 6th Nov and they sent me collets by mistake. Flagged Wed, chased on Thu, but nothing turned up by Saturday and no confirmation that anything has been sent, so looks like another week off the road. Not a big issue but I am getting impatient to drive the thing.
Sun Nov 15 2020 9:44am |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
Good luck with the valve block and the pipes.
Sun Nov 15 2020 11:03pm |
The sound advice on the prop is really appreciated
Mon Nov 16 2020 4:00pm |
A quick further comment on the valve block and seals.
Mon Nov 16 2020 4:06pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4417 |
A normal 1.8 turbo will only do around 200bhp We've had our own Freelander 1.8T featured in LROi a few years back Currently off the road for a restoration, uprated turbo and bigger injectors |
Mon Nov 16 2020 8:03pm |
That’s interesting to know. I live the idea of it.
Mon Nov 16 2020 9:51pm |
This is a long way from having anything on it
Tue Nov 17 2020 6:19am |
Tue Nov 17 2020 9:29pm |
I have all the parts now and finish work early tomorrow!!
Thu Nov 19 2020 5:58pm |
Aimed to get the thing finished today, with a few photos.
Sat Nov 21 2020 4:30pm |
Managed to find an O ring and clip to sort out the fuel leak. When did diesel designers change the name of the leak off pipes to 'spill rail'?
Sun Nov 22 2020 3:46pm |
