Home > Technical > ACE leaking |
Wafoo Member Since: 19 May 2020 Location: Pontypridd Posts: 36 |
Good shout, I'll mention it to them |
Mon Jun 29 2020 10:04pm |
the_wombat Member Since: 29 Oct 2020 Location: Huntingdon Posts: 64 |
Sorry to re-invigorate the post from June.
Fri Nov 06 2020 8:30am |
Depending on the year, I believe some vehicles have an outrigger you can remove. Mine being 2012 was fixed. Some have managed to work the pipes over the outrigger through the gap but I didn’t have the space, even after disassembling the new pipes assembly to individual pipes, removing the body bolt, loosening the body mounts and lifting the body. So I went down the route of stainless compression joints. I just made sure I numbered each end of the pipe so each half would match the correct other half. I also cleaned each pipe out after cutting to remove any swarf.
Fri Nov 06 2020 9:53am |
Fri Nov 06 2020 6:08pm |
Actually, with some time on my hands today, I decided I would lift the body on one side per other posts here.
Sat Nov 07 2020 4:45pm |
A bit more research today. I had stupidly thought that new valve block seals were only available as part of a new valve block, but they are available separately if a little expensive.
Sun Nov 08 2020 9:04pm |
I did not find it easy getting the old seals out! Had the valve block in situ as the rear pipes are OK, but decided in the end to take the whole thing to bits.
Mon Nov 09 2020 4:38pm |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 |
i saw them the other day I think, i only saw them because the fuel tank was dropped though |
Mon Nov 09 2020 5:24pm |
Mon Nov 09 2020 5:28pm |
id say just remember to remove fuel relay. also if youve dropped tank see if your filter is in it. if so may as well replace it while your there.
Mon Nov 09 2020 6:02pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4413 |
Undo the 10mm nut holding that bracket to the chassis
Mon Nov 09 2020 6:54pm |
Thanks Disco_Mikey
Mon Nov 09 2020 8:29pm |
Don't touch the clamp, undo the bracket that the clamp is bolted to
Mon Nov 09 2020 9:04pm |
Makes sense.
Mon Nov 09 2020 9:31pm |
