Home > General (L494) > InControl & Telematics Update |
DangerMouseUK Member Since: 16 Jul 2016 Location: London Posts: 528 |
For anyone who cares no idea what the Telematics update to 19.2 did but S20C has fixed the issue where USB drives with MP3s on them appear greyed out.
Sat Oct 31 2020 6:13pm |
Spleen Member Since: 04 Dec 2018 Location: Berkshire Posts: 175 |
I'm on 20B. Downloaded monthly map update last night onto USB, stick it in the car, it deletes the current versions and then this happens:
Thu Nov 05 2020 8:16pm |
Mark314 Member Since: 28 Feb 2017 Location: Basingstoke Posts: 23 |
I had a similar issue with map updates before, it was an issue with the USB drive {probably corruption} I downloaded the update to the same drive again and it installed ok next time.
Thu Nov 05 2020 11:19pm |
Cheers, I tried that but same deal. Honestly, I'm just so fed up with stuff going wrong all the time. Ferrari F430 Spider F1
Thu Nov 05 2020 11:26pm |
Join the club lol, they do wind you up sometimes.
Fri Nov 06 2020 12:03am |
Nano2nd Member Since: 23 Jul 2020 Location: Leicester Posts: 85 |
so it doesn't update over the air? 2020 Range Rover Sport P400e HSE Dynamic |
Fri Nov 06 2020 8:32am |
GV Member Since: 23 Jun 2020 Location: Shropshire Posts: 33 |
You have to use a USB download for the map bits then plug it in to the car because of the massive file size. |
Fri Nov 06 2020 8:58am |
i see, where do you download the updates from? 2020 Range Rover Sport P400e HSE Dynamic |
Fri Nov 06 2020 11:39am |
https://www.landrover.here.com/
Fri Nov 06 2020 12:17pm |
cool thanks, how do you update the non map related stuff 2020 Range Rover Sport P400e HSE Dynamic |
Fri Nov 06 2020 12:38pm |
SOTA happened this morning to 20C so plugged the USB back in and got my maps back. I can also say that the HUD definitely works in tandem with the nav as the speed display was all over the place without any maps.
Fri Nov 06 2020 6:41pm |
