Home > Technical > Definitive answer on L320 TDV8 egr delete
the_wombat
Apologies firstly if the topic has been covered. Ive spent some time merrily searching the forum and reading up on TDV8 egrs, but can’t locate a definitive answer.
The TDV8 i’ve just bought has an egr signal low error. This suggests one side is seized or clogged, with one possible solution being to remove and replace. Not beyond my capabilities but i know access is limited and the job is a pain.
The other possibility is to blank off and remove the egr setting from the ecu. I have a supplier who can do the digital part of this.
The question is whether the latter is a good thing to do, and from my research here, it seems a split viewpoint with a slight leaning towards no!
I’m keen to find out more, and wondered if more experienced members could give me some pros and cons over and above the MOT issues.
Thanks for any guidance offered or pointing me in the direction of posts i’ve yet to find.
Post #606076 Thu Oct 29 2020 10:29pm
DrRob
Lots more on the sister Full Fat forum as the engine was standard in these until 2009ish.
My take is this: blank them off with a kit and then delete from ECU. No more hassle or risk of them degrading.
Who are you using for the delete? Alive Tuning or Bell Auto Services are the "go to" for LR ECU stuff Bow down
DIY for blanks. Easy job.
https://www.fullfatrr.com/forum/topic49293.html
Replacement (I wouldn't bother though)
https://www.fullfatrr.com/forum/topic32601.html Visitor from fullfatrr.com
Post #606080 Fri Oct 30 2020 8:00am
the_wombat
Appreciated.
JC tuning is who I have found so far. Brother in Law uses them a lot for work he does on various LRs.
Not wedded to them and will search round as a check, so thanks for the links Thumbs Up
Post #606082 Fri Oct 30 2020 10:33am
gwoods1210
United Kingdom 2010 Range Rover Sport TDV8 HSE Lux Santorini Black
Are they in this area I'm in Peterborough and looking to blank and map my tdv8
Post #610767 Sun Feb 28 2021 8:47am
DrDeAtH
You could try Empire Tuning in Colchester you'll find them on Facebook
Post #611735 Sun Mar 21 2021 8:17pm
Boxers
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
gwoods 1210 if you are looking for an excellent independent to work on your vehicle I can highly recommend Avenger 4x4 in Peterborough ..
Tel.01733 301118
Owner Allen Walker.
Post #611755 Mon Mar 22 2021 11:31am
