Home > Technical > where to place front end Axle Stands
kenpassey
United Kingdom 2007 Range Rover Sport Supercharged HSE Java Black
Hi, i need to jack up my V8 Range Rover Sport, 2007 model. i need advice on where to place my Axle Stands. i will be using the cars own Jack to lift it, then hopefully place the stands.. but where is the safest place.
Can anyone post a picture of a suitable place on the front corners to help me.
im about to change my starter motor - laying on my back.. under the car.
Post #605224 Mon Oct 05 2020 10:07am
The place to put the stands is the same place that you put the jack. I'd strongly suggest you get a bottle jack or a trolley jack and avoid using the emergency jack provided with the vehicle. It's not very good and has been known to fail. If you're doing these types of project DIY, a trolley jack really is a must. You can then jack the front end up on the front subframe in one go and put the stands under chassis rails at the jacking points.
https://www.rrsport.co.uk/gallery/albums/u...acking.pdf 2012 SDV6 - it's missing a couple of cylinders
Post #605226 Mon Oct 05 2020 10:22am
there are 2 gurders that run along the car. They are about 12" in. Use these.
Careful not to damage the air tank on the passenger side.
Buy a discovery 2 red bottle jack off ebay. Well worth it.
The factory one is hopeless for even 1 use
Post #605229 Mon Oct 05 2020 11:08am
kenpassey
Thanks, yes the supplied jack must be the worst one ive ever seen, i have 2 small trolly jacks which i will use as well, cheers
Post #605231 Mon Oct 05 2020 12:09pm
PC76
Hopefully not one on top of hte other Shocked
Post #605284 Tue Oct 06 2020 10:23pm
Oldandconfused
Most of us bite the bullet and buy a high lift trolley jack, something like this;
https://www.sgs-engineering.com/tj3x-3-ton...2IQAvD_BwE
A bit of a chunky monkey to get out of the shed, but worth it for peace of mind when lifting the car.
Post #605290 Wed Oct 07 2020 6:32am
