Home > Technical > where to place front end Axle Stands |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8974 |
The place to put the stands is the same place that you put the jack. I'd strongly suggest you get a bottle jack or a trolley jack and avoid using the emergency jack provided with the vehicle. It's not very good and has been known to fail. If you're doing these types of project DIY, a trolley jack really is a must. You can then jack the front end up on the front subframe in one go and put the stands under chassis rails at the jacking points.
Mon Oct 05 2020 10:22am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4941 |
there are 2 gurders that run along the car. They are about 12" in. Use these.
Mon Oct 05 2020 11:08am |
kenpassey Member Since: 03 May 2018 Location: Liverpool Posts: 33 |
Thanks, yes the supplied jack must be the worst one ive ever seen, i have 2 small trolly jacks which i will use as well, cheers |
Mon Oct 05 2020 12:09pm |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 |
Hopefully not one on top of hte other |
Tue Oct 06 2020 10:23pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
Most of us bite the bullet and buy a high lift trolley jack, something like this;
Wed Oct 07 2020 6:32am |
