![]() | Home > General > Loss of power and black smoke |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9055 ![]() ![]() ![]() |
Is the garage a Land Rover specialist? If not, take it to one.
Wmckeown09 Member Since: 29 Apr 2020 Location: Winchester Posts: 9 ![]() ![]() |
Yes LR specialist and lots of codes some old. They can't pinpoint exactly what the issue is yet |
idi Member Since: 19 Nov 2019 Location: England Posts: 134 ![]() ![]() |
Have the codes reset, drive it around and see which oens reappear |
Flyfisherman Member Since: 12 Sep 2020 Location: Staffordshire Posts: 91 ![]() ![]() ![]() |
This is why an iid tool is a must have item when owning a rrs |
OK updated the car will start then cut out after a few seconds. The indie garage have updated that there are no new fault codes at all. They have checked all of the obvious faults including all pipes and no issues. No metal bits in oil filter so now looking to drop exhaust to see if turbo seized. But no obvious faults as yet. |
1richard1 Member Since: 10 Sep 2019 Location: oldbury Posts: 178 ![]() ![]() ![]() |
Hi is the garage a recommend indie, if not they may be trying to do a good job but at the same time not have a clue on the faults, a good local recommended indie is worth their weight in gold and the money they can save you, i can ring my local indie and as good as gold turns my money away if my symptoms are not what i think they are, and points me in the right direction. |
RRT Member Since: 26 Mar 2018 Location: South Coast Posts: 252 ![]() ![]() |
Whilst I have not used either, both West4x4 (Waltham Chase) and Petersfield Garage Services are relatively local to you and come recommended as LR Specialists MY17 RRS 4.4d V8 Autobiography - Aintree Green (also referred to on Topix as British Racing Green) |
Deleted EGR valves on a 2012 doesn’t sound right as the DPF needs them to function properly...alarm bell.
P.S if a good indie can fit you in straight away maybe not the best indie? |
OK further update I am using Rovertune in Reading who do seem good and have gone through the issue with me. Which appears to be a completely blocked DPF which may be as a result of a remap I had when I got the car. I had the EGR valves blanked and deleted but without any real proof the DPF sensor may have been deleted. So resolution is new DPF and remove map and put right the EGR valves. Would it be OK to use an aftermarket DPF or am I asking for more trouble. |
Rovertune are superb and know their onions for sure so listen to their advice |
Ash3 Member Since: 31 Aug 2019 Location: London Posts: 279 ![]() ![]() |
Rather than a new DPF...why not get yours flash cleaned. Works out way cheaper and you get mobile DPF cleaning specialists too. ![]() |
Update
Did you buy it with the remapping already done or have you paid to have it carried out? |
