![]() | Home > Faults & Fixes > Starter motor removal range rover sport 4.2 v8 supercharged |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9051 ![]() ![]() ![]() |
Download the workshop manual: http://www.mediafire.com/file/yunzrqm47py4pww/RRSL320WSM2006.pdf
kenpassey Member Since: 03 May 2018 Location: Liverpool Posts: 33 ![]() ![]() ![]() |
Thanks for the link it will be useful. Cheers. |
TheRealAdrian Member Since: 24 Aug 2023 Location: South Warwickshire Posts: 9 ![]() ![]() ![]() |
Unfortunately that link now takes you to the Owner’s Handbook rather than the Workshop Manual.
Just a follow up for the starter motor. I had a mobile mechanic have a look, it turned out to be a loose terminal connection. It was in an area I didn't have the correct extension bars to reach the nut.. he did, and got a good turn.. on the nut problem solved. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
I seem to recall this being mentioned before, it starts off with the handbook, but if you keep looking the manual is there further on, try starting around pages 425/450, or open it with adobe acrobat, document properties and set the navigation tab to bookmark panel & page it will show the different section under bookmarks. Cheers Col |
