Home > Faults & Fixes > Starter motor removal range rover sport 4.2 v8 supercharged |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9013 |
Download the workshop manual: http://www.mediafire.com/file/yunzrqm47py4pww/RRSL320WSM2006.pdf
Tue Sep 29 2020 7:44pm |
kenpassey Member Since: 03 May 2018 Location: Liverpool Posts: 33 |
Thanks for the link it will be useful. Cheers. |
Tue Sep 29 2020 8:04pm |
TheRealAdrian Member Since: 24 Aug 2023 Location: South Warwickshire Posts: 9 |
Unfortunately that link now takes you to the Owner’s Handbook rather than the Workshop Manual.
Thu Aug 24 2023 8:12pm |
Just a follow up for the starter motor. I had a mobile mechanic have a look, it turned out to be a loose terminal connection. It was in an area I didn't have the correct extension bars to reach the nut.. he did, and got a good turn.. on the nut problem solved. |
Thu Aug 24 2023 8:57pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5029 |
I seem to recall this being mentioned before, it starts off with the handbook, but if you keep looking the manual is there further on, try starting around pages 425/450, or open it with adobe acrobat, document properties and set the navigation tab to bookmark panel & page it will show the different section under bookmarks. Cheers Col |
Thu Aug 24 2023 9:50pm |
