![]() | Home > General (L494) > Whats the sim card holder for |
pko Member Since: 31 Jul 2011 Location: norfolk Posts: 193 ![]() ![]() ![]() |
Have you tried searching Sim Card? current 2015 hse dynamic, grey. |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 411 ![]() |
owners manual?? |
Spleen Member Since: 04 Dec 2018 Location: Berkshire Posts: 175 ![]() ![]() |
Once inserted you have a direction connection to Marvel World and you can transform your car into anything your heart desires. It is, after all, a robot in disguise. Ferrari F430 Spider F1 MY17 RRS AB V6 2CV6 Special |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 541 ![]() |
It’s so you can create the car to become a WiFi hotspot using that one sim....it also allows certain things to update remotely via the data card... |
Turdmon Member Since: 05 Aug 2020 Location: Lancashire Posts: 124 ![]() ![]() |
On my 2017 the sim reader is in the centre console cubby hole. Is it in a different location on the earlier ones? |
Yes on pre 17MY it is under the steering wheel at the bottom edge of the dash....it’s also a total git to get to! You have to have your head down by the pedals to insert it! |
RRT Member Since: 26 Mar 2018 Location: South Coast Posts: 251 ![]() ![]() |
Does the car require the SIM for data purposes (I have a 24gb 3 SIM card which has used less than 1Gb in 18 months) or can the car use bluetooth (or hotspot or USB cable connection) to my phone which has excess data.
It needs it for the extended options on the nav and the news and gracenote and a few other things but I’m pretty sure it doesn’t need it for the remote. My sim reader was faulty when I bought the car but I played about with it a bit using other data connections (connected to home WiFi, tethered to my phone, connected to mobile WiFi) but it was a ball ache. I had the reader replaced under warranty and the best thing to do IMO is get one of those three 12 or 24 month PAYG sims and forget about it. Mine works as it should do, although it’s no massive benefit having the sim - I just wanted it working like it should do. |
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 469 ![]() ![]() ![]() |
I put the sim in my car, I pay around £5 a month for a data only service which is linked to my phone account. Only thing I assumed it does is give you the WiFi hot spot. It only does 3G not 4G too unless I’m doing something wrong. |
MrM Member Since: 16 Jan 2016 Location: London Posts: 146 ![]() |
I believe up until 2018 the SIM card tech was only 3G, and then 4G from ‘18 on. Quite why Lord only knows.
