Home > Technical > Ride heights |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4974 |
Tue Sep 22 2020 6:23pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
With that name are you from YouTube fame ?
Tue Sep 22 2020 8:04pm |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 413 |
Thanks Col ..
Wed Sep 23 2020 5:57am |
Mine takes around 10-12 seconds to lift from standard to off-road height, that's if I start it up and put it straight into off road after being left overnight. Can't really remember what the difference between normal and off road height is, but sure someone will come along who knows, I don't think you can calibrate the normal ride height and the off road height separately if that is what you are thinking, calibrating normal height automatically sets the off road height, but again not totally certain on that one either.
Wed Sep 23 2020 7:05am |
That's helpful..spent 10years in Noosa ..wish I was there now. |
Wed Sep 23 2020 7:19am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8982 |
Col is correct, the off road and access height settings are just offsets from the calibrated normal height. You can't set them individually.
Wed Sep 23 2020 7:34am |
In high three wheels are showing 20 in and one 21. I guess the height sensor on the 21 wheel needs adjusting or has been replaced in a sloppy manor. |
Wed Sep 23 2020 7:42am |
Seems like it. 20inches is high anyway so it'll benefit from being calibrated correctly.
Wed Sep 23 2020 7:52am |
See, I knew somebody would know. What possessed you to move back to good old Blighty, nearest I ever got to Noosa was Brisbane and Sanctuary Cove on the Gold Coast.
Wed Sep 23 2020 7:56am |
Is the calibration done physically by moving the ride heigh sensors or part of an electronic diagnostic programme |
Wed Sep 23 2020 8:02am |
No, you do it using something like a Gap IID diag. or EAS tool or the likes of. Well worth investing in one.
Wed Sep 23 2020 8:11am |
samd Member Since: 21 Sep 2009 Location: Derbyshire Posts: 124 |
Should that not be 100 Kph? When I had a 12v feed wire break en route to Chesterfield from Cromer, every time I hit 60 mph, the system 'told me off' and to slow down |
Wed Sep 23 2020 9:12am |
Definitely 100mph reverts back to on road mode when speed drops back down below 80mph for 30 seconds.
Wed Sep 23 2020 9:42am |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
Different location, Andy. YouTube Piston Broke lives in South Wales. Kev MY2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey MY2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
Wed Sep 23 2020 10:48pm |
