Home > General > 5.0L SC 280k miles with wing and side damage |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
It'd be worth £3k if it was in good condition. By your description it's probably a grand, if that. Could need several thousands spending on it which is more than it's worth. It'll be worth more as parts.
Tue Sep 15 2020 8:08am |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 |
may as well post it
Tue Sep 15 2020 8:37am |
A dead battery shouldn't cause it to sink to the bump stops. As it's damaged down the passenger side, perhaps there's damage down underneath too resulting in air leaks. 2012 SDV6 - it's missing a couple of cylinders
Tue Sep 15 2020 8:54am |
Ah so the air tank could be tanked :p |
Tue Sep 15 2020 10:36am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4974 |
Could of been stood for months looking at it, what's to say someone didn't just lower suspension to make it easier to lift in a charged battery as it's been disconnected at some point as date has defaulted to 2009, but everything is pure speculation till you look at it I guess. Might be worth a cheap bid though.
Tue Sep 15 2020 11:04am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
i think the 4.2 are more reliable engines, but if you want something cheap to play with. Put in a low offer.
Tue Sep 15 2020 4:02pm |
They finally fixed the samcrac one the timing cog was off or something.
Tue Sep 15 2020 4:10pm |
managed to get hold of the reg, supposedly its been sat since 2016
Wed Sep 16 2020 7:51am |
Sam’s got a new video out.
Sun Sep 20 2020 3:56pm |
1richard1 Member Since: 10 Sep 2019 Location: oldbury Posts: 178 |
He seems to be a quick flip kind of guy |
Sun Sep 20 2020 4:56pm |
ah damnn, it is annoying when its one thing after another tbh. but if the compression test is good, and its only one bank it feels like its worthwhile going for. i didnt end up bidding on that car, copart acc didnt activate in time, but if i see a full fat 5.0L I'll be real tempted. |
Sun Sep 20 2020 5:48pm |
For the money you spend on a fixer a upper, buy a decent running one that has been looked after, if you buy a non runner but was working i think you will end up spending more than you think getting it right. These are massively complex machines that unless you can do a body off might end up biting you in the behind. |
Sun Sep 20 2020 6:27pm |
yeah but my worry is i buy a decent one and still have to do all the usual things that are gone at that age, ARC pipes, timing chain issues or top head rebuilds. Thats if I can find a mechanic who will actually do it and that i trust, but if i buy it cheap as and do it myself well I know its being done(who knows if properly ) and i get to learn a lot, plus i enjoy it. |
Mon Sep 21 2020 10:07am |
