Home > General (L494) > IIDTOOLS
41664166@online.no
Norway 2006 Range Rover Sport TDV6 Autobiography Rimini Red
IIDTOOLS
Hello. Have changed car and want and use IIDTOOL BT on our new car. Range Rover Sport L494 2014.
How do I go ahead and get it work on this model.
Have sold the previous car, Range Rover Sport 2006
TrondL
Post #604302 Tue Sep 08 2020 9:18am
Drewlr4
Plug it into the new car then go into config and connect then you will get an activation code which you need to email the GAP and they send a new code to activate it on the new vehicle and deletes it from the old one.
Post #604307 Tue Sep 08 2020 10:15am
I don't think an IIDTool for an L320 will work with the L494. Best to ask Gap themselves. They're pretty good at responding to direct queries. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #604310 Tue Sep 08 2020 11:18am
41664166@online.no
Have sent them emails several times without and get a response back from them
Whats the right mailadress ?
Post #604319 Tue Sep 08 2020 1:16pm
Stevepd
Send an enquiry https://www.gap-diagnostic.com/support/contact/ 2006 2.7 TDV6 HSE in Cairns Blue.
Post #604322 Tue Sep 08 2020 1:53pm
41664166@online.no
Thanks so far.
With this diagnostic tool IIDTool can you program the car so that the handbrake goes on by itself every time you park the car.
Also want the taillights to light up all the time, even during the day when it's bright. and not just when driving into a tunnel or when it is dark.
Last edited by 41664166@online.no on Mon Sep 14 2020 9:26am. Edited 1 time in total
Post #604394 Wed Sep 09 2020 6:32pm
41664166@online.no
BUMP
Post #604539 Mon Sep 14 2020 9:26am
You can on a L320 so imagine you can on a L494, applies when you turn the ignition off or put in in park I think but can't really remember.
Post #604540 Mon Sep 14 2020 10:08am
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
41664166@online.no wrote:
BUMP
As Col said yes on an L320, I'm not sure if all models are the same but my MY13 applies it when switching off the engine while in gear, but not if already in Park.
Yes you can set the tail lights to be on all the time but front side lights are also on, you set it to Canadian or Scandinavian. From memory Canadian turns the lights on when selecting drive, Scandinavian turns them on when the engine starts. 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #604545 Mon Sep 14 2020 12:51pm
41664166@online.no
Now I got to program the park brake so it goes on when you stop the engine.
But need help to get the taillights on all the time.
Someone who knows how to do this with IIDTools
Post #604553 Mon Sep 14 2020 5:12pm
Posted this about 5 years ago, gives the different options for DRL activation on the L320, not sure if it the same with the L494 though as they already have DRL's, but with the earlier cars to have taillights on all the time so are dipped headlights.
Have gone into the CCF files and there are three options listed on my car a MY13 A/B 5.0L S/C.
1. DRL Standard
2. Scandinavian
3. Canadian
I Activated Standard and all that did was give me two Fault Codes B124A-15 and B124B-15 which are Left and Right Daytime Running Light open Circuit but no working DRL's so it may be when you have either DRL lamp kit VPLSV0064 or 65 fitted you may have to activate this but that is purely a guess. By the way those kit's are over �400.00
De-activated that and then Activated Canadian and what that did was nothing with ignition on and Engine Running, however when you engage Drive and let the Park Brake Off it Switched Front and Rear Side Lights and Dipped Headlights On, as soon as you apply P/B and take it out of Drive It switches them Back Off.
Again De-activated that and Activated Scandinavian and what that did was as soon as you Start Engine it Switched on Front and Rear Sidelights and Dipped Headlights.
There is no facility that I could find to just activate the Front Fairy Lights on there own as DRL's.
I hope that all makes some kind of sense.
Post #604554 Mon Sep 14 2020 8:30pm
