Home > General (L494) > IIDTOOLS |
Drewlr4 Member Since: 05 Aug 2020 Location: South Devon Posts: 55 |
Plug it into the new car then go into config and connect then you will get an activation code which you need to email the GAP and they send a new code to activate it on the new vehicle and deletes it from the old one.
Tue Sep 08 2020 10:15am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9016 |
I don't think an IIDTool for an L320 will work with the L494. Best to ask Gap themselves. They're pretty good at responding to direct queries. 2012 SDV6 - it's missing a couple of cylinders
Tue Sep 08 2020 11:18am |
41664166@online.no Member Since: 01 May 2015 Location: Moss Posts: 128 |
Have sent them emails several times without and get a response back from them
Tue Sep 08 2020 1:16pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
Send an enquiry https://www.gap-diagnostic.com/support/contact/ 2006 2.7 TDV6 HSE in Cairns Blue. |
Tue Sep 08 2020 1:53pm |
Thanks so far.
Wed Sep 09 2020 6:32pm |
BUMP
Mon Sep 14 2020 9:26am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5032 |
You can on a L320 so imagine you can on a L494, applies when you turn the ignition off or put in in park I think but can't really remember.
Mon Sep 14 2020 10:08am |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 |
As Col said yes on an L320, I'm not sure if all models are the same but my MY13 applies it when switching off the engine while in gear, but not if already in Park. Yes you can set the tail lights to be on all the time but front side lights are also on, you set it to Canadian or Scandinavian. From memory Canadian turns the lights on when selecting drive, Scandinavian turns them on when the engine starts. 13MY Range Rover Sport Autobiography SDV6 - mine 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite Last edited by insiorc on Mon Sep 14 2020 8:46pm. Edited 1 time in total |
Mon Sep 14 2020 12:51pm |
Now I got to program the park brake so it goes on when you stop the engine.
Mon Sep 14 2020 5:12pm |
Posted this about 5 years ago, gives the different options for DRL activation on the L320, not sure if it the same with the L494 though as they already have DRL's, but with the earlier cars to have taillights on all the time so are dipped headlights.
Mon Sep 14 2020 8:30pm |
