Home > Maintenance & Modifications > Red battery urgent |
Craigb86 Member Since: 09 Jul 2020 Location: Wales Posts: 74 |
So daft question as a newbie can I drive it as I pick my daughter up for access weekend |
Wed Sep 09 2020 8:13am |
as in would I cause damage to car |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 |
For folks not too clued up on basic electrics then a cheap little tool can provide good info on what's going on with the battery and charging system without having to figure out a multimeter (yes a multimeter is invaluable in knowledgeable hands). It's a BM2 battery monitor which is left permanently attached to the battery which connects to your phone etc. via blutooth and stores volt data for 28 days. Even for folk familiar with a multimeter this is a handy tool (I've got 27 years experience using them for work)
Wed Sep 09 2020 8:44am |
Just order that one it makes sense to have that view defo and I've booked the car in for some other jobs that needed doing and will get new alternator same time as its cheaper then and looking on the forum these cars seem to poop alternators so its likely to be nearly dead anyhow so I don't think its a bad move would you say? |
Wed Sep 09 2020 10:51am |
syl Member Since: 10 Mar 2016 Location: Somerset Posts: 412 |
You can usually pick a multimeter up same day from Screwfix for less than £10. If the one you ordered doesn’t arrive, get one there and send the other one back. RRS MY17 SDV6 AB
Wed Sep 09 2020 10:57am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4986 |
does that battery monitor give you any indication like the ctek traffic light system? (via the app) ?
Wed Sep 09 2020 10:59am |
Will do its in 12th October for all my other work from the car dealer being underhand so ots had its safety check for small claims court case so may as well sort the alternator at same time just billed separate job then
Wed Sep 09 2020 11:44am |
OK so I quickly checked on my lunch break
Wed Sep 09 2020 2:23pm |
let me know if i should do one terminals off as i can do that once I finish at 5 i tried to squeeze it in while munching my sandwich as I only get 20 mins lol |
Wed Sep 09 2020 2:25pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
The battery is about 70% charged so that's good (unless it was fully charged beforehand). The idling voltage looks a bit low. If you turn on some decent load - heated screen, for example - what does the voltage do then? 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Wed Sep 09 2020 3:33pm |
Will check that now and my charger said it was full but its only a little charger I will nip straight out at 5 and grab a few tests is there any other to try to give most idea as possible
Wed Sep 09 2020 3:36pm |
Are you meaning the Ctek monitor? If so I've never seen it, but it's nothing like that useless Ctek traffic light on the charger connector, I have one of them but now ignore the lights, I would only suggest people spend the extra on them as the leads are fused. Here are some screenshots showing the other displays and options; The live voltage screen with instantaneous graph (history as shown in graphs posted earlier is graphs at 2 minute intervals) Settings Alternator test at idle and high revs (I think 2500rpm but not positive) Cranking test Trip history 13MY Range Rover Sport Autobiography SDV6 - mine 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
Wed Sep 09 2020 3:42pm |
No the volt meter i got delivered today |
Wed Sep 09 2020 3:56pm |
OK so got this
Wed Sep 09 2020 4:11pm |
