Home > Maintenance & Modifications > Red battery urgent |
Craigb86 Member Since: 09 Jul 2020 Location: Wales Posts: 74 |
Well ive booked in for alternator this morning along with a list of stuff so it would be Ideal if those results point to alternator
Wed Sep 09 2020 5:28pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8988 |
Bear in mind that a dodgy battery can kill an alternator. Be prepared to replace both but hope only the alternator is required. 2012 SDV6 - it's missing a couple of cylinders
Wed Sep 09 2020 9:38pm |
Yea im prepared for that and almost tempted for sake of £150 more for new battery same time then kts warrantied |
Wed Sep 09 2020 9:41pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4982 |
Dennis, does it matter which side of the BMS module the neg. terminal is connected? Cheers Col |
Wed Sep 09 2020 10:01pm |
Col, I'm not 100% sure what you mean, I fitted the monitor unit inside the battery box and connected to a spare threaded hole on the +ve battery clamp then ran the -ve lead out of the battery box to an earth point just outside. There are red & black coloured fork crimps aleady fitted so I assume is polarity sensitive. 13MY Range Rover Sport Autobiography SDV6 - mine 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
Thu Sep 10 2020 10:53am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4966 |
It's not drawing any significant current so I don't think it matters to the car.
Thu Sep 10 2020 11:06am |
Dennis, I assumed the monitor connected direct to pos. and neg. battery terminals, but as on the sport the BMS bolted on the neg. terminal post just wondered if it made a difference as when hardwired a ctek plug in it was recommended the neg. terminal was connected to earth point on the vehicle not the neg. battery terminal, I realise the ctek and the monitor serve two different purposes, but just wondered if it made a difference as would not describe myself as a auto electrician. However from what you say that is how you wired the monitor in anyway.
Thu Sep 10 2020 11:29am |
Col, I never thought much about it, I probably would have gone directly across the battery except the -ve was tucked under the scuttle panel area so a pest to get to (probably battery out), I chose the external earth out of lazyness 13MY Range Rover Sport Autobiography SDV6 - mine
Thu Sep 10 2020 11:33am |
I'm curious as to why the engine idle volt readings seem to be the focus but not when the engine has higher rev's?
Thu Sep 10 2020 11:38am |
Under load it counted down none stop from 13 to 11.9 before i turned it off so it didn't drop too low to cause more damage. As you said I put on high beam and heater to create load and it was losing voltage as fast as counting down would be |
Thu Sep 10 2020 2:16pm |
A good battery should have held that load for a while before dropping to that level, especially if not long since being charged. But it's quite common for a knackered battery to take out the alternator aswell. 13MY Range Rover Sport Autobiography SDV6 - mine
Thu Sep 10 2020 2:20pm |
Well alternator is booked in so will get a battery myself and leave it in passenger footwell and say once the alternator is fitted change battery
Thu Sep 10 2020 2:21pm |
