![]() | Home > General (L494) > Glovebox |
sterling01 Member Since: 19 Apr 2015 Location: Kilmarnock Posts: 137 ![]() ![]() |
Quick question. The glovebox on my car just drops like a stone when you open it. Is it meant to be that way or should it have a soft opening? Current - 2020 Range Rover Sport P400e
Cornishman Member Since: 12 Jul 2018 Location: Cornwall Posts: 27 ![]() ![]() |
Just opened mine,on My 16, drops slowly, looks like a curved plastic rack and wheel on sides doing the biz. |
Ash3 Member Since: 31 Aug 2019 Location: London Posts: 279 ![]() ![]() |
Same here
Drewlr4 Member Since: 05 Aug 2020 Location: South Devon Posts: 55 ![]() ![]() |
Soft open on my 494 2014 |
tsinc80697 Member Since: 10 Aug 2020 Location: Manchester Posts: 57 ![]() ![]() ![]() |
Soft open on my 2017 |
Love JLR consistent approach to manufacturing |
Even my RRS1 opens slowly, assuming the RRS2 is similar to the RRS1 check that the little gearwheel/damper in the attached picture has some resistance when turning it as it should have, or if the teeth are broken or stripped.
Thanks Col, will have a look later Current - 2020 Range Rover Sport P400e
Part number linked above is for a LHD vehicle. Rimmer Bros website is wrong. As I have found out.
Sorry my mistake, FFZ500090 looks to be listed for the r/h/d L320 and l/h/d L494, is the damper on the opposite side on the L494 then? by the passengers door not the console.
Eventually got this sorted. The correct part number for a right hand drive vehicle is FFZ500080.
