![]() | Home > Technical > Oil Leak - could this lead to other major issues |
I'd personally not use a main dealer but seek out a decent independent specialist in your area e.g. Oval Autos in Cradley Heath and Alltrack in Malvern are good.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9055 ![]() ![]() ![]() |
I'm with Rob on this. I'd get it to a decent indie. If nothing else, it'll reduce the cost. It'll probably lead to a better outcome too as LR's dealers aren't known for being meticulous and thorough in their work. 2012 SDV6 - it's missing a couple of cylinders
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
As I was reading your post I was thinking " he's not gone to a LR Dealer has he?". So I concur with my two learned friends who've gone before me. Get it away from the dealer (assume its not warranty work) and find a good local independent LR specialist. Robin
akalair Member Since: 21 Feb 2020 Location: coventry Posts: 28 ![]() ![]() ![]() |
After some toing and froing, the approved used warranty team have agreed to cover the leak as i reported a potential oil leak at the same time as the diff. (warranty expired over lockdown)
If the mechanic doing the job does it properly, there shouldn't be any future issues associated with it.
As above at least it’s covered by warranty but now your out of it find a local indie, perhaps like DrRob has said above. Stay far away from main dealers now |
Resurrecting this thread. Looking for help and advice....
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1195 ![]() ![]() ![]() |
A leaking rear diff pinion seal is quite common, and they should have fixed it quite easily - but it looks like they didn't.
