Home > Maintenance & Modifications > Tow bar wiring question
Devon Z
England 2005 Range Rover Sport TDV6 HSE Java Black
So I’m in the process of wiring the 12s socket and the 12volt ignition supply Red/White is not active, the trailer fuse F22 (10amp) behind the glovebox which is an ignition supply is there. Any ideas or is there somewhere else I pick one up? Thinking rear compartment 12volt socket? Steve
2005 2.7 TDV6 HSE, ongoing project.
1998 Volvo V70 R auto FWD, mothballed future project.
1999 BMW Z3 (owned from new) garage queen.
Post #603646 Sun Aug 23 2020 2:31pm
Try red wire at relay base. As that comes from the fuse.
See if you have power at the fuse with ignition on
Maybe you need to plug in a mini relay at the rear for it to work (in the area behind the rear Left light) There is already a wiper relay there.
But Yeah use power socket other wise
Post #603647 Sun Aug 23 2020 2:41pm
Devon Z
Thanks Andy, yep relays in but not switching, I’ll take the ignition supply from the red and put a fuse in it to be safe.
 Steve
Post #603650 Sun Aug 23 2020 3:38pm
Are those clear things fuses you have been adding
Post #603651 Sun Aug 23 2020 3:45pm
oh.
I bet it clicks.
The problem is there is no power on the blue.
There should be a fuse between blue and the thick green/brown (live feed for trailer), that's the problem
If you were to fit a 15A fuse at the LR trailer socket it would work as intended and power the red/white
Post #603652 Sun Aug 23 2020 3:47pm
Devon Z
That’s it Smile cheers Andy I’d never of thought of that. The clear fuses are part of the LR 12n socket, that bridge must be part of the LR 12s loom? I’ve fitted a generic 12s socket.
Thanks again mate Very Happy Steve
Post #603653 Sun Aug 23 2020 4:27pm
That’s correct
Post #603654 Sun Aug 23 2020 5:06pm
