Home > Technical > Snapped Crankshafts?
PeteF74
United Kingdom 2011 Range Rover Sport SDV6 HSE Lux Orkney Grey
I've just scared myself silly and read about snapped crankshafts on RRS's Shocked and was wondering how much of a problem this is and which models are the most affected?
The common cause seems to be put down to a manufacturing defect and oil starvation. Is there any way to prevent this happening or is it luck of the draw?
I am now trawling the net for a decent warranty provider..........
Post #603235 Thu Aug 13 2020 11:37am
No prevention, and no way of predicting if/when it will happen.
Pot luck, really, and JLR usually don't bother helping with the repair costs.
IIRC even their own warranty excludes this. --
Post #603238 Thu Aug 13 2020 12:18pm
knwatkins
All 2.7 and 3.0 diesels are susceptible to the issue, across all LR models. The 3.0 is simply an evolution of the 2.7.
The likelihood is low compared to the thousands of cars on the road. But when it happens...it hurts. Kev
Post #603270 Fri Aug 14 2020 7:28am
Eaters
If I remember reading something on this forum correctly, I recall that the problem is in the design of the big end bearings. In the good old days when I used to rebuild my MGB engine, you had big end shells with a little tab which located in a recess in the crankshaft. Once located and bolted up, there was no way that the shells could move. This meant that the oil ways all lined up.
IIRC the problem with the LR engines in question is that they have done away with the little tab meaning that the shells can slide around the crankshaft. It they do this then the oil hole no longer lines up and the bearing are starved of oil. Bang!
Of course I could have dreamed all this. I am sure that someone will be along to either confirm my recollections or tell me I'm talking out of my .... Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #603314 Sat Aug 15 2020 7:38am
knwatkins
No, your not dreaming it Robin. Lots of people think that.
The reality is though, the newer 3.0 have tabbed bearings and those bearings spin, block the oilways and cause the crank to snap also.
Whilst tabs *may* reduce the risk somewhat, they do not stop the bearings rotating.
There are many engines without tabbed bearings and they do not suffer with the same issue.
Here's a pic of one of my big end bearings from last year Big Cry
 Kev
Post #603316 Sat Aug 15 2020 8:03am
mgrover
dumb question but when they occur is the entire engine just destroyed? i mean is a rebuild completely out of the question if i managed to buy the car at rock bottom prices?
Post #603494 Thu Aug 20 2020 9:45am
Eaters
Off Topic I know it is off topic as I'm straying into MG territory, but I can't understand how the shells could move in the bearing with a tab - unless they break off, of course. Once tightened up, they can't move. My MG engine was built before 1967 and still works. Sounds to me like LR have designed out a perfectly serviceable and functioning part for no apparent reason.
From the MG Workshop Manual. That little tab "A" fits in the groove "B" and that that sorted!
Bloody LR! Robin
Gone:
MGZTT 190 2.5
Post #603496 Thu Aug 20 2020 10:32am
I thought for some reason that was part of the problem, someone in their infinite wisdom decided the shells/rods didn't need the locating tabs anymore.
Post #603498 Thu Aug 20 2020 10:57am
Disco_Mikey
In all of the 3.0 engine failures I've seen through our doors, every single one, without exception has been low on oil at time of failure...
Post #603502 Thu Aug 20 2020 12:54pm
knwatkins
No, rebuilds are possible. If the bearing has turned, the chances are that the block is still good and the crank can take a regrind.
If the crank has given way, the chances are that the block would have warped and a rebuild will cost a lot more because you will need to find a good block.
Here's my post when it happened to me...
https://www.disco3.co.uk/forum/oval-autos-...80253.html Kev
Post #603503 Thu Aug 20 2020 1:31pm
What do you call low mike ? Below min?
Post #603507 Thu Aug 20 2020 6:20pm
Disco_Mikey
Sub 3L...
The engine oil, while acting as a lubricant, also acts as a coolant, taking heat away from the hot metal spinny bits, and transferring it elsewhere to the engine. The hotter the oil gets, the less lubrication it can provide
One if these areas the oil flows through is the (aptly named) oil cooler
This has galleries of engine oil and engine coolant. The coolant draws heat from the oil, and flows through the radiator, whereby, it looses that heat. The "cooled" oil (still 90+ degrees) continues its flow around the engine, lubricating things as it goes. And its a continual process
The less oil in the engine, the less heat transfer can take place, and the oil gets hotter and hotter until it provides less and less lubrication, and thats when engine wear and damage occurs...
At a capacity of less than 3 litres, thats less than half the recommended amount of oil
And thats before we get into the chemistry of engine oil degrading quicker as its being worked harder as there is less of it. Its all above my head anyway, TBH Laughing
Of all these engine failures, I wonder just how many still had a full 5.8 litres of oil in the sump...
Post #603511 Thu Aug 20 2020 6:41pm
Humm. That is low.
Post #603514 Thu Aug 20 2020 7:35pm
DrRob
I wonder if folks don’t check oil levels like we used to years ago Whistle Visitor from fullfatrr.com
Post #603516 Thu Aug 20 2020 8:11pm
The emissions friendly electronic dipsticks don't help. You need the engine to be "just so" where an old dipstick you could wander out and check it any time you liked.
But I have no doubt that people generally don't check the oil / coolant / PAS etc. like we used to. 2012 SDV6 - it's missing a couple of cylinders
Post #603521 Thu Aug 20 2020 9:20pm
