Home > Technical > Snapped Crankshafts?
Tony_Boats
When my engine went it was to the max in oil, but, I can’t confirm why it failed, just reported as metal bits in the oil, it would still run albeit roughly !
Post #603523 Thu Aug 20 2020 10:30pm
abiopete
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Disco_Mikey wrote:
Sub 3L...
The engine oil, while acting as a lubricant, also acts as a coolant, taking heat away from the hot metal spinny bits, and transferring it elsewhere to the engine. The hotter the oil gets, the less lubrication it can provide
One if these areas the oil flows through is the (aptly named) oil cooler
This has galleries of engine oil and engine coolant. The coolant draws heat from the oil, and flows through the radiator, whereby, it looses that heat. The "cooled" oil (still 90+ degrees) continues its flow around the engine, lubricating things as it goes. And its a continual process
The less oil in the engine, the less heat transfer can take place, and the oil gets hotter and hotter until it provides less and less lubrication, and thats when engine wear and damage occurs...
At a capacity of less than 3 litres, thats less than half the recommended amount of oil
And thats before we get into the chemistry of engine oil degrading quicker as its being worked harder as there is less of it. Its all above my head anyway, TBH Laughing
Of all these engine failures, I wonder just how many still had a full 5.8 litres of oil in the sump...
This is good news to me at least who changes every 6 months and checks the oil every week.
Wonder if there's anyone on the forum with the proper amount at the time of failure? L494 3.0L SDV6 Autobiography in Chile Red (Current)
L320 3.0L SDV6 Autobiography in Baltic Blue (RIP 29/03/2021 insurance total loss)
Post #603542 Fri Aug 21 2020 10:14am
Tyrefitter
I changed my oil twice a year & when I sold my14 AB within a week the crankshaft went. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #603554 Fri Aug 21 2020 1:29pm
erickwan
Malaysia
Disco_Mikey wrote:
In all of the 3.0 engine failures I've seen through our doors, every single one, without exception has been low on oil at time of failure...
That's saying a lot. Why and how are these engines running low on oil?
Are there particular reasons?
Does your comment apply to the 2.7L or just 3.0L
Post #639498 Fri Feb 09 2024 10:08am
riverblanche
Hi,
it might be worth you doing a New Search for more up to date info
as it was 3 1/2 years ago and much has been wrote on the subject since then
gone Porsche Cayenne 2020
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #639561 Sun Feb 11 2024 12:11am
erickwan
Malaysia
As I posted in a previous topic:
https://www.rrsport.co.uk/forum/topic61827.html
There are 7 versions of oil pumps through the life of the engine. What do Ford/PSA/JLR know that we don't, and what are they possibly hiding from us?
It takes a lot of financial and manpower resources to investigate the "not so obvious" causes of crankshaft failure. Resources us as individual owners, would not have access to.
I am of the opinion that they have already nailed the cause(s) of crankshaft failure, but are not telling us to avoid lawsuits or out of warranty claims. The failures are quickly seen to, so that the relevant owners do not take matters any further.
They might be selling us goods that are "not fit for purpose", items just waiting to blow up in our faces, and might "probably" know it.
Post #639564 Sun Feb 11 2024 1:47am
NoExpert
Oil cooler has also been revised on the 3.0’s. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #639577 Sun Feb 11 2024 1:23pm
Pistnbroke
United Kingdom 2009 Range Rover Sport TDV6 HSE Galway Green
LR time seem to think the failure of Fabians crank was a manufacturing defect ..
When I worked in the motor trade in Coventry I worked with a man who spent his time at the factory testing components that had been incorrectly heat treated to "see if they would last the warrantee period".
These were mainly gearbox parts.
However when asked how they got miss heat treated he told me that the workers often wanted a week off in term time to take the kids on a cheap holiday .that week there brother went in to do their job ...oh yes he was a milkman ! foreman and unions turned a blind eye.
Want a gearbox ..no problem .hang it on a rope around the workers neck.push through the gates with a gang of mates around pick it up at the pub...EPLS Always listen to old people or when they die you will live on in ignorance.
The avatar is a picture of the man with a big cock.
Learned to 4x4 on 100 mile beach and Frazer Island QLD
Dont spend money on old cars you will never get it back
Post #639595 Mon Feb 12 2024 9:14am
