Home > General > front screen causes revs to drop slightly? |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 |
The front screen heater draws a very big electrical load, the fall in RPM is because the alternator suddenly has to provide this and causes a significant drag on the engine that takes a little time to respond.
Thu Aug 13 2020 4:42pm |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 |
fair enough nothings bust then ive gotta get the rear spoiler off and see why the rear one isnt working next. |
Thu Aug 13 2020 5:58pm |
Seatown Member Since: 15 Mar 2019 Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands Posts: 100 |
Begs the question as to why you're putting on the screen heating in this weather? 2010 TDV8 - current - my first RRS, loving it so far...... 2005 Cayenne S - handling defied physics and what a sound, so sod the mpg! 1995 Disco TDI- surprisingly reliable, shame about the peeling dash & other trim Lots of other non 4X4's in between times......... |
Thu Aug 13 2020 10:54pm |
I was just messing around curious :p |
Fri Aug 14 2020 7:34am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
The heated windscreen draws 27.5A each side, so 55A in total. 2012 SDV6 - it's missing a couple of cylinders
Fri Aug 14 2020 7:56am |
hmm from what ive noticed in the past the driver side seems not to work as well as the passenger so i wonder if its a seperate fuse which is knackered? |
Fri Aug 14 2020 10:33am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
It’s probably wishful thinking.
Fri Aug 14 2020 11:19am |
Yeah my screen was the same only half worked well |
Fri Aug 14 2020 12:12pm |
Don't forget that the side airbag pack lives on the A-pillar behind the trim so just be a bit careful when accessing it all. Be really annoying to set that off! 2012 SDV6 - it's missing a couple of cylinders
Fri Aug 14 2020 2:40pm |
idi Member Since: 19 Nov 2019 Location: England Posts: 134 |
I like how you just say that so casually. Like its common knowledge to know these things. |
Fri Aug 14 2020 4:02pm |
idi - info available in the workshop manual that is freely available to download. Took me 2 minutes to open the manual and check the wiring diagram. 2012 SDV6 - it's missing a couple of cylinders
Fri Aug 14 2020 11:00pm |
Do you guys ever think might be handy to just have a massive faq post :p I feel bad spamming a million and one things everyday thats gone wrong :p today's is hesitation to drop down gears when putting foot down but not using kickdown |
Sat Aug 15 2020 5:05am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4974 |
I think that would be a very long index of questions with no answers, taking into account not everybody can be bothered posting a reply when they get the issue fixed to maybe help others with the same or similar issue. I think it would be quicker to keep asking you questions.
Sat Aug 15 2020 5:15am |
There is a “Search” function on the tool bar below the forum banner so no need for an FAQ section 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sat Aug 15 2020 7:56am |
