Home > General > Schoolboy Error
Pufftmw
Schoolboy Error
Driving into Swansea a bit late for meeting a train, so pressed on in the B-roads and hit the motorway. Strange vibration noticeable, slight wobble of the wheel. Got to Swansea and checked around the car and saw the wheel nuts on the NSR seemed a bit prominent Shocked Even more Shocked Shocked when they moved in my fingers...
Unless someone came and undid them, then I can't have tightened them after adjusting the EBC. I recall at the time deciding to use my torque wrench to set them right but I guess I only did them finger tight and forgot to do one side Rolling Eyes
NEVER EVER IN 40 YEARS OF CHANGING WHEELS HAVE I EVER FORGOTTEN TO TIGHTEN A WHEEL Big Cry Big Cry Big Cry
No damage done other than to my ego though...
Post #603257 Thu Aug 13 2020 9:27pm
Autobiography1969
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #603258 Thu Aug 13 2020 9:42pm
I had similar once. Except I hadn't been playing with the wheels so no idea why they were loose. Had been parked in a corner slot in a multi-storey car park so wonder if someone had been trying to nick it before realising how heavy an RRS is... 2012 SDV6 - it's missing a couple of cylinders
Post #603262 Thu Aug 13 2020 11:23pm
Tyrefitter
Not good but at the end of the day we are all human & make mistakes,have you checked you wheel for damage where the nut sits.? If damaged they could come lose again so it might mean a new wheel. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #603265 Fri Aug 14 2020 5:57am
aaronjb
If it makes you feel any better, I once finished a track day (in my old E46 M3, not the RRS Laughing ) and drove home from - if memory serves - Oulton Park to Bracknell.. a little way from Oulton I started getting that characteristic "whomping" drone of a failed wheel bearing; worse turning one way than the other etc.
Convinced myself a wheel bearing had failed and chalked it up to over enthusiasm..
Got home and checked the wheel bolts to find one set of rears finger tight Shocked
Whoopsy. Good job it's only 183 miles between Oulton & Bracknell! Embarassed 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #603273 Fri Aug 14 2020 8:48am
Hog
Netherlands 2012 Range Rover Sport SDV6 HSE Lux Buckingham Blue
It happens even in F1 RRS 3.0 SDV6 HSE Lux
RRS 3.0 TDV6 gone
LR 3 HSE V8 gone
DiscoveryII V8 Gone
Discovery 1 V8 Gone
Mustang Shelby
Alfa Guilia (classic)
Post #603287 Fri Aug 14 2020 3:48pm
Eskimo
Had the same happen to, embarrassingly I took it to the local independent as I had no idea what was going on with it. Hadn't been playing with wheels or anything.
Had had the wheels balanced about 3wks before and the noise got steadily worse, when he said what the problem was it was a rather Embarassed Embarassed Embarassed , however the other mechanic said that mine had been the 3rd RRS in 2 weeks with the exact same problem..........
They didn't really know why, but tightened all the wheel nuts up again and not had a problem since. Intersetingly though the powder coating on my wheels was ridiculously thick, and I've since had the wheel refurbished and the coating is much thinner. I wondered if it was an effect of the thick powder coating and temperatures causing the wheel nuts to loosen? 2006 RRS HSE 2.7 TDV6 (The Baby one as I keep being told)
1999 Discovery 4.0 V8 (Gone but not forgotten)
1997 Range Rover 3.5 V8 (Long gone now)
1966 Series II SWB with RR 3.5 V8 (Never finished, now sold)
Post #603582 Fri Aug 21 2020 8:10pm
Devon Z
England 2005 Range Rover Sport TDV6 HSE Java Black
I know how you feel but trust me you’ll never do it again.
I got fired from my first job as machanic at 20 because I forgot to put a split pin a half shaft nut after a brake service, now I always check and double check. Steve
2005 2.7 TDV6 HSE, ongoing project.
1998 Volvo V70 R auto FWD, mothballed future project.
1999 BMW Z3 (owned from new) garage queen.
Post #603585 Fri Aug 21 2020 8:44pm
aaronjb
I am carrying around a little mental note that the rear hub nuts on my kit car have never been torqued .. let's hope I remember before it hits the road!
(The fronts are old fashioned spindles with twin taper bearings, so your note about a split pin reminded me - the fronts have split pins but the rears are torqued like a modern bearing) 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #603680 Mon Aug 24 2020 10:05am
Eaters
What's the kit aaronjb? Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #603695 Mon Aug 24 2020 3:01pm
aaronjb
It's a Dax Cobra replica - Jaguar XJ40 hubs front & rear and differential, albeit with modified driveshafts.. Jaguar stuff of that era (~1990s) is a wonderful mix of imperial and metric fasteners on every part Laughing
I'm glad JLR had finally settled on metric by 2009! Mr. Green 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #603703 Mon Aug 24 2020 3:49pm
tsinc80697
United Kingdom 2013 Range Rover Sport 4.4 V8 Autobiography Firenze Red
Been there, done that Whistle I lost a locking nut after I didn't tighten it up a few years ago!
Post #603744 Tue Aug 25 2020 9:39am
Eaters
Hey - sounds great. Robin
Gone:
MGZTT 190 2.5
Post #603747 Tue Aug 25 2020 9:53am
