Home > General > HDC system fault,park brake fault, driving me crazy
Millermagic
Netherlands 2009 Range Rover Sport TDV6 HSE Bourneville
Hi All, new to the group.
I have a 2009 2.7 sport, A couple of weeks ago I had to change the front wheel due to a puncture ever since I have had HDC fault,park break fault,suspension lean.it is a miss match tyre at the moment.
Sometimes the car starts first time then fault appears and shuts down audio and hazards flash but still drives then comes back to life other times car will not turn over, Battery seems ok 12v standing 14v running, dynamic fluid was low but I have topped up,
Unfortunately I do not have a code reader. any help would be much appreciated.
Thanks Lee [/code][/quote]
Post #602857 Thu Aug 06 2020 11:35am
A mismatched tyre can do silly things if the rolling circumferences are very different. Alternatively, a knocked ABS sensor on the corner that has had the wheel changed might cause issues.
If the battery is at 12V then that's quite low - down to about 40%-50% charged. A fully charged battery is around 12.7-12.8V measured after standing unused for 24 hours. You might find a full charge with a decent charger would be useful. These beasts like a healthy battery with lots of charge in it. 2012 SDV6 - it's missing a couple of cylinders
Post #602873 Thu Aug 06 2020 5:33pm
Millermagic
Thanks for the help, will be getting new tires to start with.
Post #603043 Sun Aug 09 2020 4:33pm
