Home > Maintenance & Modifications > Range Rover automatic tailgate aftermarket kit
jason-nike
I remember reading on here somewhere this kit was fitted by a member.
Is this kit easy to fit as it looks fairly straightforward
https://www.autoease.com/product/liftgate/
Post #602667 Sun Aug 02 2020 8:42pm
LG8340
England 2013 Range Rover Sport SDV6 HSE Lux Santorini Black
I fitted the kit on MY12 which means anyone can. Great piece of kit. You won't regret it. RRS (MY13) Santorini Black SDV6 HSE luxuary
Gone: Evoque, Freelander 2, Mercedes 320 CLK, Porsche 911's
Post #602709 Tue Aug 04 2020 1:18am
I'm surprised you needed to fit it on a MY12. I thought they all had the power tailgate as standard.
Hopefully the aftermarket kit is more reliable than LR's version which has a habit of not opening correctly from time to time. 2012 SDV6 - it's missing a couple of cylinders
Post #602713 Tue Aug 04 2020 8:37am
I might be wrong here but I think might be getting muddled up between the powered tailgate conversion for pre MY12 cars and the powered closure mod for the MY12 on cars to close the tailgate via the key fob or dash button as well as switch in the tailgate
Post #602714 Tue Aug 04 2020 9:09am
jason-nike
I mean the power tailgate kit as mine is a 2011 so manual tailgate.
looking to see if the retrofit kit is straightforward
Post #602739 Tue Aug 04 2020 5:39pm
Ptang
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
After reading this I reached out to Autoease and they sent over the installation guide for the RRS 05-09 so I could have a look. It's a PDF - what's the best way to share this here if anyone is interested?
'tang.
Post #602858 Thu Aug 06 2020 11:35am
knwatkins
Maybe put it on Google Drive a share a link? Kev
Post #602869 Thu Aug 06 2020 4:12pm
Ptang
Moved over to my gallery (Thanks RRSTDV8!)
Give this a go > https://www.rrsport.co.uk/gallery/albums/u...V6.0.3.pdf
'tang.
Post #602871 Thu Aug 06 2020 5:11pm
You can put pdf in your gallery and just share them for there. Just to let you know for later. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #602875 Thu Aug 06 2020 5:42pm
jason-nike
'tang.
Thats great to read.
Thanks for sharing the instructions
Post #602893 Thu Aug 06 2020 9:12pm
Does say you can't power close it from the front dash button so I wonder if you can fit the power close mod kit used on the one piece tailgate so the button will close it as well, doesn't specifically say you can close it from the key fob either which the power close mod does as well. I think I would also ask if the original press button in the tailgate will power it open rather than having to use the dash button or key fob or if it just releases it as normal as no mention of that, I also assume the tailgate glass still opens separately as I think that would still be quite useful, as miss that a bit with the one piece tailgate.
Post #602903 Fri Aug 07 2020 7:30am
HughN
Wales
Why does it need an SD card? Software update?
Post #603074 Mon Aug 10 2020 10:04am
knwatkins
To feedback tailgate usage data from the Chinese spyware Whistle Kev
Post #603075 Mon Aug 10 2020 10:21am
Eaters
Rolling with laughter Rolling with laughter Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #603092 Mon Aug 10 2020 1:09pm
