Home > Maintenance & Modifications > Range Rover automatic tailgate aftermarket kit |
jason-nike Member Since: 08 Nov 2013 Location: sussex Posts: 207 |
I remember reading on here somewhere this kit was fitted by a member.
Sun Aug 02 2020 8:42pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
I'm surprised you needed to fit it on a MY12. I thought they all had the power tailgate as standard.
Tue Aug 04 2020 8:37am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4969 |
I might be wrong here but I think might be getting muddled up between the powered tailgate conversion for pre MY12 cars and the powered closure mod for the MY12 on cars to close the tailgate via the key fob or dash button as well as switch in the tailgate
Tue Aug 04 2020 9:09am |
I mean the power tailgate kit as mine is a 2011 so manual tailgate.
Tue Aug 04 2020 5:39pm |
Ptang Member Since: 11 Jan 2008 Location: Bromley, Kent Posts: 95 |
After reading this I reached out to Autoease and they sent over the installation guide for the RRS 05-09 so I could have a look. It's a PDF - what's the best way to share this here if anyone is interested?
Thu Aug 06 2020 11:35am |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
Maybe put it on Google Drive a share a link? Kev
Thu Aug 06 2020 4:12pm |
Moved over to my gallery (Thanks RRSTDV8!)
Thu Aug 06 2020 5:11pm |
You can put pdf in your gallery and just share them for there. Just to let you know for later. 2012 SDV6 - it's missing a couple of cylinders
Thu Aug 06 2020 5:42pm |
Thats great to read. Thanks for sharing the instructions |
Thu Aug 06 2020 9:12pm |
Does say you can't power close it from the front dash button so I wonder if you can fit the power close mod kit used on the one piece tailgate so the button will close it as well, doesn't specifically say you can close it from the key fob either which the power close mod does as well. I think I would also ask if the original press button in the tailgate will power it open rather than having to use the dash button or key fob or if it just releases it as normal as no mention of that, I also assume the tailgate glass still opens separately as I think that would still be quite useful, as miss that a bit with the one piece tailgate.
Fri Aug 07 2020 7:30am |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 |
Why does it need an SD card? Software update? |
Mon Aug 10 2020 10:04am |
To feedback tailgate usage data from the Chinese spyware Kev
Mon Aug 10 2020 10:21am |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1538 |
Robin
Mon Aug 10 2020 1:09pm |
