Home > Maintenance & Modifications > Towbar electrics
Snowy030
United Kingdom 2009 Range Rover Sport TDV6 HSE Santorini Black
Towbar electrics
Hi all I've justed fitted the electrics for a towbar 12s&12n
All went quite easy but now I've been told that I have to have it tested / car programmed it that true ? Before it can be used
Post #602261 Sun Jul 26 2020 8:24pm
Duc750
It should work as it is but the car will not recognise a trailer hung on it so any stability programs will not kick in, rear parking sensors won't shut down and the fog lights will stay active 2012 SDV6 HSE (technically its hers)
2000 D2 TD5 - definitely mine
2005 D3 V8
Metalian Camper trailer for adventures
Post #602266 Sun Jul 26 2020 9:02pm
Phil2k
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Santorini Black
I've just fitted mine for our horse trailer, it only uses 12n but works fine if you don't mind muting the parking sensor when reversing
Post #602272 Mon Jul 27 2020 12:06am
Devon Z
England 2005 Range Rover Sport TDV6 HSE Java Black
Re: Towbar electrics
Mine has the 12n fitted but I have yet to fit the 12s, did you use a LR kit or universal?
Don’t think we’ll going anywhere with our van anytime soon so no rush. Steve
2005 2.7 TDV6 HSE, ongoing project.
1998 Volvo V70 R auto FWD, mothballed future project.
1999 BMW Z3 (owned from new) garage queen.
Post #602282 Mon Jul 27 2020 9:42am
Phil2k
I used a LR kit from pf Jones. Took an hour and a half to fit on my own. Just had to get a hand with the rear bumper to put it somwhere it wouldn't scratch. Possible to do on your own though
Post #602283 Mon Jul 27 2020 9:54am
Devon Z
Thanks Phil, was the plug for the 12s socket behind the near side panel same as 12n? Whoever fitted the 12n to my car drilled a hole in the boot floor to bring the loom into the car, don’t think the plug on the LR loom will go through it did they go the wrong way? Steve
Post #602286 Mon Jul 27 2020 10:38am
Phil2k
Yes, both sockets on near side behind the number, no need for any drilling at all, remove mud flaps, remove tred plate on bumper, remove lights then remove bumper. All is there ready for you
Post #602287 Mon Jul 27 2020 10:44am
Devon Z
Cheers Phil, obviously they didn’t take the bumper off to do the 12n then Confused Job on my list is rear bumper removal to clean up and de rust so I’ll do the socket then. Steve
Post #602288 Mon Jul 27 2020 10:57am
Snowy030
Thanks to all who answered my questions
All sorted now
Post #602296 Mon Jul 27 2020 1:14pm
aaronjb
Fitted 13-pin electrics to mine without removing the bumper .. and no drilling required either! Just bendy hands.. comes up through the factory grommets. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #602298 Mon Jul 27 2020 1:21pm
Duc750
Aaron you must have about 14 extra joints in your arms then. The D4 can be done without but needs a small child to get the last fixing in 2012 SDV6 HSE (technically its hers)
2005 D3 V8
Post #602303 Mon Jul 27 2020 2:43pm
