Home > Maintenance & Modifications > Towbar electrics |
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 |
It should work as it is but the car will not recognise a trailer hung on it so any stability programs will not kick in, rear parking sensors won't shut down and the fog lights will stay active 2012 SDV6 HSE (technically its hers)
Sun Jul 26 2020 9:02pm |
Phil2k Member Since: 18 Jun 2020 Location: Anglesey Posts: 75 |
I've just fitted mine for our horse trailer, it only uses 12n but works fine if you don't mind muting the parking sensor when reversing |
Mon Jul 27 2020 12:06am |
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 314 |
Mine has the 12n fitted but I have yet to fit the 12s, did you use a LR kit or universal? Don’t think we’ll going anywhere with our van anytime soon so no rush. Steve 2005 2.7 TDV6 HSE, ongoing project. 1998 Volvo V70 R auto FWD, mothballed future project. 1999 BMW Z3 (owned from new) garage queen. |
Mon Jul 27 2020 9:42am |
I used a LR kit from pf Jones. Took an hour and a half to fit on my own. Just had to get a hand with the rear bumper to put it somwhere it wouldn't scratch. Possible to do on your own though |
Mon Jul 27 2020 9:54am |
Thanks Phil, was the plug for the 12s socket behind the near side panel same as 12n? Whoever fitted the 12n to my car drilled a hole in the boot floor to bring the loom into the car, don’t think the plug on the LR loom will go through it did they go the wrong way? Steve
Mon Jul 27 2020 10:38am |
Yes, both sockets on near side behind the number, no need for any drilling at all, remove mud flaps, remove tred plate on bumper, remove lights then remove bumper. All is there ready for you |
Mon Jul 27 2020 10:44am |
Cheers Phil, obviously they didn’t take the bumper off to do the 12n then Job on my list is rear bumper removal to clean up and de rust so I’ll do the socket then. Steve
Mon Jul 27 2020 10:57am |
Snowy030 Member Since: 26 Jul 2020 Location: Gloucestershire Posts: 2 |
Thanks to all who answered my questions
Mon Jul 27 2020 1:14pm |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
Fitted 13-pin electrics to mine without removing the bumper .. and no drilling required either! Just bendy hands.. comes up through the factory grommets. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
Mon Jul 27 2020 1:21pm |
Aaron you must have about 14 extra joints in your arms then. The D4 can be done without but needs a small child to get the last fixing in 2012 SDV6 HSE (technically its hers)
Mon Jul 27 2020 2:43pm |
