![]() | Home > Maintenance & Modifications > advice please on jacking up rrs |
Normally people just jack them up using a proper jack.
adam01 Member Since: 24 Jul 2020 Location: roscommon Posts: 9 ![]() ![]() ![]() |
ive a 3 ton trolly jack , but when i jack it up wheels do go off the ground -but quickly wheels go down before i could get wheel nuts off |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 950 ![]() ![]() ![]() |
Have you checked to make sure it's not your jack that is the problem, one of my jacks does that,,,, and it's not exactly an old unit but it won't hold any substantial weight. One of these days I will repair it. 2010 RRS, TDV8
Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436 ![]() ![]() |
Does the book not say to raise it to off road height? Joined the X5 45e club
Perhaps your jack does not have enough reach?
1richard1 Member Since: 10 Sep 2019 Location: oldbury Posts: 178 ![]() ![]() ![]() |
Hi if your jack hasn't the reach lock it in access mode. |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
Having spent some time today jacking mine up, jacking on the lower rear arms pivot on a 43cm 3 tonne Halfords trolley jack gets the wheels off the ground enough to get axle stand under and without maxing out. |
What is this lock thing - there is no such thing as far as jacking goes - you jack the car up and the wheels stay on the ground until suspension travel is used up and then the wheel lifts. What is with the truck boot open - this is nonsense. The official way is put the car in offroad height - this is to minimise the amount of lift on the jack you have to do - put the jack under the jacking point under the chassis and start jacking, and jacking, and jacking and after a long time the wheel comes off the ground - then you can remove the wheel. If you have a trolly jack or a hydraulic jack you can put it under the relevant front wish bone and if it is safe, when you jack it will lift the wheel off the ground directly rather than lifting the body first until the suspension range is exhausted then the wheel lifts. 07MY RRS TDV6 Arctic Frost Aspen Interior |
ondafly Member Since: 03 Mar 2017 Location: Ireland Posts: 50 ![]() ![]() ![]() |
do you happen to have put the car into access mode ? and thus its lowered/compressed the suspension. I've always jacked it up when in normal height, and just pumped away with a 3tonne trolley jack. No problems at all. Put chocks on the back wheels also. |
thanks guys did the brake pad change
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 ![]() ![]() ![]() |
Correct! That's the way it should be done! (and leave one door open)
RRS 3.0 SDV6 HSE Lux RRS 3.0 TDV6 gone LR 3 HSE V8 gone DiscoveryII V8 Gone Discovery 1 V8 Gone Mustang Shelby Alfa Guilia (classic) |
If you are jacking off the wishbone rather than the chassis then the height of the vehicle does not matter. Also having a door open had no effect - it will stop a change of height which has to be activated with the console switch but does not stop the car leveling. 07MY RRS TDV6
