![]() | Home > Maintenance & Modifications > Oil leak |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
According to this there are gaskets fitted (£30.00 each for genuine L/R one's), in addition to having to put a couple of beads of silicone sealant in the areas marked with arrows.
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 ![]() ![]() ![]() |
That looks perfect, cheers Col. Ama get some tracer fluid next week and if its the gaskets hopefully its a nice easy change. Although I doubt it |
Bit of an update to this, did my right side, the gaskets don't fit, so I was like well my fault for not getting oem, so I went and bought oem. Same issue their too small. Lr said they'd been revised. I ended up cutting my old gasket and patching this one with some gasket sealer. Not pretty but does the job.
