![]() | Home > General > Dashcam power |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 923 ![]() ![]() |
Here is a write up of what I did. Have fun
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
Not sure about the Aux but there is a Permanent Live up there in the Grey Plug to the left, red wire pin 1 if I remember right, plug normally used for sunroof.
idi Member Since: 19 Nov 2019 Location: England Posts: 134 ![]() ![]() |
Good write up. I'll give it a go on the weekend. Thanks. |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 ![]() ![]() |
Don't forget to buy a voltage regulator (if that's what they're called?) with the appropriate USB connector (either micro or mini) for your dash cam.
Would that not depend on the make of Dashcam being fitted, never had to fit voltage regulator on a Blackvue or Thinkware as they must be integral part of camera.
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 782 ![]() ![]() ![]() |
Probably most decent dashcams are 12v these days, my Thinkware is and so is the wifes Nextbase.
I piggy backed off Fuses 48 (Live) and 52 (Aux) fed the wires from the cam between the roof panel and headlining, down the door post under the door seal in to the fuse box, easy enough. If you have the rear cam as well did basically the same with that, fed the cable over the headlining and through the rubber conduit sleeve by the tailgate to the rear screen.
derekmines Member Since: 22 Apr 2019 Location: MELKSHAM Posts: 133 ![]() ![]() ![]() |
I used the ignition switched live up in the overhead console but instead of powering the camera directly I used a cigar lighter socket that I then plugged the normal dashcam power lead into... there's plenty of room in the headlining to lose the socket and it will make upgrading the camera much easier in the future. |
How much do these reduce your insurance by? |
abiopete Member Since: 27 Feb 2020 Location: Manchester, UK Posts: 169 ![]() ![]() ![]() |
Didn't know they did, will be mentioning it on my next policy L494 3.0L SDV6 Autobiography in Chile Red (Current)
I don't know. I assume that was why Admiral kept asking me. |
I agree with Scrumpy, most are between 3-5 volts. Check the dashcam instructions to verify what you need first. I would be wary of telling your insurance company, as if they give you a reduction on the policy, they will be expecting it to be on all the time your using the car. Nice get out for them if for any reason its not on or heaven forbid you are "slightly" above the speed limit when you have an accident. They are good to have if its not your fault, but you decide when to show the footage, not the insurance company. |
As Col says, I'm sure there are plenty of 12v models out there and probably the more expensive ones have something built in.
Have to admit I generally have the voice recording and speed stamp turned off |
