Home > General > Dashcam power |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 897 |
Here is a write up of what I did. Have fun
Mon Jul 06 2020 9:48pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4968 |
Not sure about the Aux but there is a Permanent Live up there in the Grey Plug to the left, red wire pin 1 if I remember right, plug normally used for sunroof.
Mon Jul 06 2020 10:01pm |
idi Member Since: 19 Nov 2019 Location: England Posts: 134 |
Good write up. I'll give it a go on the weekend. Thanks. |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 |
Don't forget to buy a voltage regulator (if that's what they're called?) with the appropriate USB connector (either micro or mini) for your dash cam.
Mon Jul 06 2020 10:59pm |
Would that not depend on the make of Dashcam being fitted, never had to fit voltage regulator on a Blackvue or Thinkware as they must be integral part of camera.
Mon Jul 06 2020 11:11pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
Probably most decent dashcams are 12v these days, my Thinkware is and so is the wifes Nextbase.
Tue Jul 07 2020 6:45am |
I piggy backed off Fuses 48 (Live) and 52 (Aux) fed the wires from the cam between the roof panel and headlining, down the door post under the door seal in to the fuse box, easy enough. If you have the rear cam as well did basically the same with that, fed the cable over the headlining and through the rubber conduit sleeve by the tailgate to the rear screen.
Tue Jul 07 2020 7:24am |
derekmines Member Since: 22 Apr 2019 Location: MELKSHAM Posts: 133 |
I used the ignition switched live up in the overhead console but instead of powering the camera directly I used a cigar lighter socket that I then plugged the normal dashcam power lead into... there's plenty of room in the headlining to lose the socket and it will make upgrading the camera much easier in the future. |
Tue Jul 07 2020 7:50am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4940 |
How much do these reduce your insurance by? |
Tue Jul 07 2020 7:57am |
abiopete Member Since: 27 Feb 2020 Location: Manchester, UK Posts: 169 |
Didn't know they did, will be mentioning it on my next policy L494 3.0L SDV6 Autobiography in Chile Red (Current)
Tue Jul 07 2020 9:11am |
I don't know. I assume that was why Admiral kept asking me. |
Tue Jul 07 2020 9:18am |
I agree with Scrumpy, most are between 3-5 volts. Check the dashcam instructions to verify what you need first. I would be wary of telling your insurance company, as if they give you a reduction on the policy, they will be expecting it to be on all the time your using the car. Nice get out for them if for any reason its not on or heaven forbid you are "slightly" above the speed limit when you have an accident. They are good to have if its not your fault, but you decide when to show the footage, not the insurance company. |
Tue Jul 07 2020 11:44am |
As Col says, I'm sure there are plenty of 12v models out there and probably the more expensive ones have something built in.
Tue Jul 07 2020 6:09pm |
Have to admit I generally have the voice recording and speed stamp turned off
Tue Jul 07 2020 9:17pm |
