Home > General > L494 MY2014 Autobiography - Unused connector |
Heremyjill Member Since: 01 Jun 2020 Location: Shrewsbury Posts: 89 |
Hello from a RRS newbie,
Thu Jul 02 2020 3:16pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
The photo is in the OP's gallery:
Fri Jul 03 2020 8:29am |
Fri Jul 03 2020 9:44am |
Do they fit a transport relay somewhere when they're on the transporter trucks? Might this be where it's plugged in? 2012 SDV6 - it's missing a couple of cylinders
Fri Jul 03 2020 11:03am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
thats usually under the bonnet.
Fri Jul 03 2020 11:35am |
That has some hefty wire going to it! 2019 5.0 SC SVA (Current)
Fri Jul 03 2020 11:38am |
idi Member Since: 19 Nov 2019 Location: England Posts: 134 |
Touch the pins together with a screwdriver, see what fuse goes and then you'll know |
Fri Jul 03 2020 10:04pm |
Thank you and yes that is a good idea about the fuse. I am not sure how I would easily find out which fuse has blown though.
Wed Jul 08 2020 7:54am |
I think that was mostly a joke suggestion |
Wed Jul 08 2020 10:25am |
Not getting too much luck with this question. How about I phrase it differently?
Fri Jul 24 2020 3:59pm |
A highly probable use for this connector has been found. Thank you to PJBracer1
Sat Aug 15 2020 11:18am |
