![]() | Home > General > L494 MY2014 Autobiography - Unused connector |
Heremyjill Member Since: 01 Jun 2020 Location: Shrewsbury Posts: 90 ![]() ![]() ![]() |
Hello from a RRS newbie,
The photo is in the OP's gallery:
Do they fit a transport relay somewhere when they're on the transporter trucks? Might this be where it's plugged in? 2012 SDV6 - it's missing a couple of cylinders
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
thats usually under the bonnet.
That has some hefty wire going to it! 2019 5.0 SC SVA (Current)
idi Member Since: 19 Nov 2019 Location: England Posts: 134 ![]() ![]() |
Touch the pins together with a screwdriver, see what fuse goes and then you'll know |
Thank you and yes that is a good idea about the fuse. I am not sure how I would easily find out which fuse has blown though.
I think that was mostly a joke suggestion |
Not getting too much luck with this question. How about I phrase it differently?
A highly probable use for this connector has been found. Thank you to PJBracer1
