Home > Maintenance & Modifications > Wiper Blades
StuartK
United Kingdom 2011 Range Rover Sport SDV6 Autobiography Alaska White
Wiper Blades
Hi Guys,
Has anyone retrofitted the Bosch flat blades or should I just stick with the standard ones?
Thanks
Post #599574 Wed Jun 03 2020 3:26pm
Dave B
Bosch Aero Twin I think they are called, I wouldn't fit anything else now.
Dave 2010 3.6 TDV8 HSE (Gone)
2011 Discovery 4 Commercial SDV6 (Gone)
1980 OBLIC 4.0ltr Range Rover (went a long time ago)
Post #599575 Wed Jun 03 2020 3:36pm
StuartK
Thanks Dave that's what im thinking.
As ever ECP are listing several different ones so looks like im visiting them!
Post #599576 Wed Jun 03 2020 4:03pm
Silverstone
United Kingdom 2012 Range Rover Sport Supercharged HSE Baltic Blue
Same here recently fitting the Bosch Aero Twin. Very pleased with them. There is no replacement for displacement - W O Bentley
MY2013 5.0 Supercharged HSE L320
Post #599582 Wed Jun 03 2020 5:58pm
All personal preference, I fitted the bosch and binned them after a month as thought they were crap, noisy and juddering and that was on a new screen.
Post #599592 Wed Jun 03 2020 9:22pm
knwatkins
I have the Bosch flat blades on mine and they are great.
These are the ones you need Stuart, if you are getting from ECP...
485775830 Bosch Wiper Blade (Super Plus Specific Wiper Blade Rear H403) (Rear)
485778210 Bosch Wiper Blade (Retrofit Flat Wiper Blade Single Ar21U) (Left)
485778220 Bosch Wiper Blade (Retrofit Flat Wiper Blade Single Ar22U) (Right) Kev
Post #599594 Wed Jun 03 2020 10:38pm
StuartK
Thank you Smile
Post #599606 Thu Jun 04 2020 12:24am
Brit Plumber
I have Bosch on my car and I won’t fit them on the front again as they are slightly wider than OEM and the end of the blade contacts my A pillar trim if I have them on fast action. It gets a little annoying when it starts tap, tap, tapin. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #599669 Thu Jun 04 2020 8:05pm
Martyns
United Kingdom 2007 Range Rover Sport TDV8 HSE Bonatti Grey
i have just fitted these, very similar to the bosch. fraction of the price... fit well. easy, and no sqeaking or juderring
https://www.amazon.co.uk/dp/B07FYNFGH5/ref...11_TE_item
Post #601044 Tue Jun 30 2020 8:57am
DrRob
I put HQ ones off eBay on my L322. £18 a pair and superb quality Thumbs Up Visitor from fullfatrr.com
Post #601051 Tue Jun 30 2020 11:33am
I've got Bosch ones on mine. Seem to work fine.
I also use Rain-X in the screenwash which means the wipers aren't often needed at A-road and motorway speeds. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #601052 Tue Jun 30 2020 11:35am
DrRob
Rain X in screenwash. Like that idea Bow down
Tell me more Thumbs Up Visitor from fullfatrr.com
Post #601053 Tue Jun 30 2020 11:47am
https://www.halfords.com/motoring/screenwa...24322.html
or
https://www.halfords.com/motoring/screenwa...03244.html
Ideally you want to fill the reservoir from empty (or near empty).
I have also used:
https://www.halfords.com/motoring/screenwa...77623.html
The only issue I've had with Rain X is in some limited conditions you can get smearing first thing, but it goes away fairly quickly. 2012 SDV6 - it's missing a couple of cylinders
Post #601058 Tue Jun 30 2020 12:34pm
Lindab
If you use rainx, you only need to do a flick wipe at city speeds. Above around 40-50mph the water just blows away so you hardly ever use the wipers. It keeps the screen cleaner also. I do not know the last time I filled the washer bottle as I never have to clean the screen. Used it for years Very Happy
Get the small bottles that you wipe on the screen rather than the washer additive
https://www.rainx.co.uk/
Post #601060 Tue Jun 30 2020 1:23pm
DrRob
Thumbs Up Bow down Visitor from fullfatrr.com
Post #601063 Tue Jun 30 2020 3:21pm
