Home > Maintenance & Modifications > Can anybody tell me the name of the part missing in this pic
IggyIggins
United Kingdom 2009 Range Rover Sport TDV8 HSE Santorini Black
As the title suggests, had the car up on a ramp today and mechanic says there is a part missing from the square area in the middle of the green circle. Anybody know what it is? I've googled loads of stuff and can't find anything.
As far as I'm aware it's just missing an undertray but they seem to think it's missing something substantial/structural
Post #601013 Mon Jun 29 2020 7:26pm
Is it not just this bit? nothing else. Looks like we got that wrong Laughing
Post #601025 Tue Jun 30 2020 4:38am
garrycol
Australia
You are missing the tow loop cover.
https://www.ebay.com/itm/06-09-Range-Rover...2544482414 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #601047 Tue Jun 30 2020 10:43am
as per gary.
look like you will need 4 square clip receivers too (if they aren't in the holes)
Post #601050 Tue Jun 30 2020 12:24pm
IggyIggins
Appreciate the answers guys, it was in fact this piece I was after (Undertray) But I've ordered a towing eye cover too!
http://landroverusedspares.co.uk/Range-Rov...-Undertray
Much obliged! Smile
Post #601253 Fri Jul 03 2020 10:39pm
garrycol
Australia
As far as I can remember, I thought the engine under tray is two piece - a rectangular piece right forward under the radiator and the piece you have ordered which sits under the actual engine. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #601258 Sat Jul 04 2020 2:01am
Eaters
My Indie told me some time ago that I had an under tray missing and this post has prompted me to have a look at it and get it sorted. And I think you are right garrycol as I have the front cover (which presumably hides the tow loop) but the one further back is missing - the engine one.
So - before I order one, if you've ordered the wrong one IggyIggins, and don't want it, then let me know as I might buy it off you.
My front (Radiator?) undertray
The gap where I think my other undertray should go
 Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #601272 Sat Jul 04 2020 2:49pm
I would just like to point out that engine undertray is very heavy.
So.
1 postage will be a lot
2 it very heavy / difficult to remove at oil changes.
If it were me, I wouldn't be bothering to replace it !
Post #601275 Sat Jul 04 2020 4:00pm
Eaters
OK - sage advice. I think I'll stay as I am then. Thanks Andy
What are the two hoses I can see as they seem to be a bit vulnerable. Robin
Gone:
MGZTT 190 2.5
Post #601276 Sat Jul 04 2020 4:11pm
knwatkins
That's one of your diesel coolers, Robin.
Personally, I'd replace the undertray. It provides protection and keeps things clean. But that's just me - I don't like driving around having bits missing!
It really isn't a hassle unbolting it to do an oil change. It's only a few bolts. Kev
Post #601277 Sat Jul 04 2020 4:35pm
10 ? Heavy duty bolts
I then have to prop it on wood when refitting cus you can’t really lift it easily on your own and get a bolt started
Post #601283 Sat Jul 04 2020 6:15pm
Eaters
Hmm - I'm a bit of a hands off guy on RRS maintenance and leave it to my Indie. So maybe I'm back in the market for the under tray...
I used to be so indecisive but now I don't know... Robin
Gone:
MGZTT 190 2.5
Post #601286 Sat Jul 04 2020 6:21pm
garrycol
Australia
The main plate protects the engine sump (amongst other things) - and yes the pic above does show the smaller rectangular plate forward of the engine that I mentioned earlier.
The main plate is easy to remove with a rattle gun and while solid is easy to put back up solo (I am 66). I have cut a circular hole in mine, under the sump plug so I can drain engine oil without removing the plate.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #601296 Sun Jul 05 2020 2:03am
I'd replace it too. Easy enough to do with a trolley jack if you have one. I've had mine off a couple of times and it's not too onerous.
May as well have the protection it provides, even if just from the odd stone chucked by a tyres, or a bit of branch on a road on a windy day. If you ever venture off the tarmac, you'd definitely want it. 2012 SDV6 - it's missing a couple of cylinders
Post #601311 Sun Jul 05 2020 10:45am
I think there's a gearbox undertray missing too. That's a plastic one and easy to deal with.
There are three undertrays. The small metal one at the front immediately behind the towing eye, there's a large metal one that sits under the chassis rails and then there's a plastic one that sits under the gearbox. 2012 SDV6 - it's missing a couple of cylinders
Post #601316 Sun Jul 05 2020 10:51am
