Home > Maintenance & Modifications > Egr delete a no brainer ?
Martyns
United Kingdom 2007 Range Rover Sport TDV8 HSE Bonatti Grey
I've read so many posts now about the egr delete that it almost seems a no brainer ! Very few have said oh leave it in , engine's designed for them ... my rr sport tdv8 2007
still has them , it's had new turbos , new injectors , new turbo pipes , I believe it's mapped but I've found under hard acceleration it puts out smoke , not lots , and only under hard acceleration, no smoke on start or tick over , but just wanted to know if egr delete will stop this or if you just have to live with that as it's a V8 lump running diesel ?
I know there's heaps of other benefits to blanking them so im pretty sure I'll have it done anyway Smile
Anyone know a good rr indi around Farnham ?
Thanks in advance
Post #600712 Wed Jun 24 2020 7:09am
Oldandconfused
Apart from any legal implications (tampering with emission equipment and insurance issues), had it been a 2.7 I would say yes.
However, I'm sure I read in a thread that DM, the LR guru of this parish, advised against EGR blanking on the TDV8. May be worth having a search on here.
Post #600722 Wed Jun 24 2020 8:56am
skid1963
Re: Egr delete a no brainer ?
Thanks in advance
Have a word with Archie at https://www.mts4x4.co.uk/
He's an ex LR Tech, nice bloke, knows what he's doing and no bullshine with it, prices are pretty good too Thumbs Up
Not far from you in Alton 2015 L494 SDV6 3.0 HSE Dynamic
2006 L320 4.2 Supercharged
2009 BMW X5 M-Sport - Gone
2007 L320 2.7TDV6 SE Buckingham Blue - Gone
2011 Jaguar XFS 3.0V6 Diesel - Gone
2009 (59) L320 Facelift 3.0TDV6 HSE White Wrap - Gone
2008 BMW X5 M-Sport - Gone
2005 Audi A6 3.2V6 Quattro S-Line - Gone
Post #600736 Wed Jun 24 2020 12:45pm
its not recommended on the TD V8
Post #600741 Wed Jun 24 2020 3:20pm
The TDV8 requires a map change to blank the EGR. A simple "bang in a plate and off you go" approach doesn't work apparently.
The EGRs one my old TDV8 were changed at about 160k miles. Not because they had failed but because they were taken off to do something else and it seemed silly to put the old ones back on. Had they not been taken off anyway, they'd have still been on there now, I'd say. It's currently on over 180k miles (it lives elsewhere in the village now). 2012 SDV6 - it's missing a couple of cylinders
Post #600752 Wed Jun 24 2020 5:15pm
Thanks in advance
A little black smoke under hard acceleration is normal. It's a result of slight over fuelling, in effect. A bad remap can do this too. Removing the EGRs won't help unless one of them has failed in the open position. A failed EGR would throw up an EML anyway. 2012 SDV6 - it's missing a couple of cylinders
Post #600753 Wed Jun 24 2020 5:19pm
Dave B
As RRSTDV8 says, a little black smoke is normal under hard acceleration, infact for almost all diesels.
Mine does it and I have no DPF or other boxes to hold deposits until they are 'blown' away, and I've had new Borg Warner turbos and a carbon clean (which exposed the exhaust manifolds as having a leak) fitted recently.
If nothing on start up and when tickling around, I'd say you have nothing to worry about.
Dave 2010 3.6 TDV8 HSE (Gone)
2011 Discovery 4 Commercial SDV6 (Gone)
1980 OBLIC 4.0ltr Range Rover (went a long time ago)
Post #600755 Wed Jun 24 2020 5:26pm
