Home > General (L494) > A/C running hot |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
How long have you had the car? Kev
Wed Jun 17 2020 1:41pm |
glenn9999 Member Since: 31 Aug 2019 Location: Essex Posts: 58 |
picked it up 28th feb and due to covid not used it until 2 weekends ago |
Wed Jun 17 2020 2:09pm |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1176 |
Discovered something similar yesterday: the ambient air was cold (+-16C), yet when I put the fan on, it started blowing hot air, even with the temperature set at 16C (no aircon).
Wed Jun 17 2020 2:14pm |
Gibo993 Member Since: 22 Feb 2020 Location: Sunninghill Posts: 8 |
Any independent garage with AC gassing machine can run diag, to check system. They do lose gas if not used as seals harden as oil needs to circulate. Regas should be no more than £150 (they need 800g of gas for 4 zone which os quite a lot). |
Sat Jun 20 2020 8:21am |
I would just take it back to them and tell them it isn't working. Kev MY2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey MY2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
Sat Jun 20 2020 9:40am |
told them this and they want to charge me just to look at it
Sat Jun 20 2020 3:27pm |
mrsammyp Member Since: 04 Nov 2019 Location: Kent Posts: 56 |
Just had the same issue in my car.
Sat Jun 20 2020 4:39pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9016 |
They're trying to put you off getting it looked at so it falls outside the 6 months from purchase. Within 6 months, they are required to fix it. Take it back and insist that they fix it as required by the law.
https://www.theaa.com/car-buying/legal-rights[/u] 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Sat Jun 20 2020 5:52pm |
As above. They need to fix it. Don't let them mess you around. Kev
Sat Jun 20 2020 6:21pm |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 |
Hello
Sat Jun 20 2020 6:23pm |
I paid cash but paid the deposit on card |
Sun Jun 21 2020 5:21pm |
so car has been to an indy this morning system was leak tested and result was no leaks
Mon Jun 22 2020 10:23am |
perfect result. My freind runs a very busy garage and says most manufacturers only fill cars with enough gas to make the system function. So with RRs it can take 800g but will still work with 405g. They have tested new cars straight from the showroom and found this to be the case, sneaky eh! |
Wed Jun 24 2020 6:26am |
Gents, if the engine has been working hard, is it normal for the non-aircon air to be hot? --
Wed Jun 24 2020 7:09am |
