Home > General (L494) > A/C running hot
glenn9999
A/C running hot
Hello all
i have tried my A/C for the first time this weekend since buying the call and i have found that its blowing hot air
i have spoken to my local LR dealer as the car is an approved used and i have been told that i need to pay £300-400 for them just to diagnose the issue and that they never need to be recharged so it will not be that
is this correct ?
Post #600375 Wed Jun 17 2020 2:07pm
knwatkins
How long have you had the car? Kev
Post #600378 Wed Jun 17 2020 2:41pm
glenn9999
picked it up 28th feb and due to covid not used it until 2 weekends ago
Post #600380 Wed Jun 17 2020 3:09pm
Discovered something similar yesterday: the ambient air was cold (+-16C), yet when I put the fan on, it started blowing hot air, even with the temperature set at 16C (no aircon).
the car just came back from a service, maybe they messed up the filter change? --
Post #600381 Wed Jun 17 2020 3:14pm
Gibo993
Any independent garage with AC gassing machine can run diag, to check system. They do lose gas if not used as seals harden as oil needs to circulate. Regas should be no more than £150 (they need 800g of gas for 4 zone which os quite a lot).
Post #600563 Sat Jun 20 2020 9:21am
knwatkins
I would just take it back to them and tell them it isn't working. Kev
Post #600566 Sat Jun 20 2020 10:40am
glenn9999
told them this and they want to charge me just to look at it
i have booked it in for an A/C check monday with an indy and if its anything wrong its going to land rover as its still under warranty
Post #600577 Sat Jun 20 2020 4:27pm
mrsammyp
Just had the same issue in my car.
They did a recharge and as no obvious damage have added some dye into the air con system.
I’ve got to take it back in a couple of weeks, if the dye can been seen then they will look to repair under the approved warranty, if no dye found they will charge me the £180 for the recharge. MY2017 RRS Capathian Grey
Post #600579 Sat Jun 20 2020 5:39pm
They're trying to put you off getting it looked at so it falls outside the 6 months from purchase. Within 6 months, they are required to fix it. Take it back and insist that they fix it as required by the law.
Quote:
Faults, repairs and refunds
Under the new act, if a fault renders the product not of satisfactory quality, not fit for purpose or not as described, then the buyer is entitled to reject it within the first 30 days.
Between 30 days and 6 months
If a fault comes to light after 30 days but before 6 months you’re entitled to a repair, replacement or refund.
It’s assumed in law that the fault was present at the time of purchase unless the seller can prove otherwise.
Unless you’ve agreed otherwise, the seller (dealer) has only one opportunity to repair (or replace) the faulty vehicle after which, if they fail to repair it, you’re entitled to a refund.
In the event of a refund following a failed attempt at repair during the first six months the seller may make a 'reasonable' adjustment to the amount refunded to take account of the use that you’ve had of the vehicle.
After 6 months
The burden is on you to prove that the product was faulty at the time of delivery if you want to pursue a claim for repair or replacement.
https://www.theaa.com/car-buying/legal-rights[/u] 2012 SDV6 - it's missing a couple of cylinders
Post #600584 Sat Jun 20 2020 6:52pm
knwatkins
As above. They need to fix it. Don't let them mess you around. Kev
Post #600586 Sat Jun 20 2020 7:21pm
shepp
Hello
Did you buy with credit? And did it say on the advert it had aircon.
I paid the deposit for mine with a credit card and paid cash for the rest. I had a faulty heated windscreen, and they tried everything to try get out of replacing it, contacted barclay card (only paid a couple of hundred deposit)
They sorted it out in no time..
The dealer doesn't have a leg to stand on, just threaten to share your experience.
Hope you get it sorted MY12 RRS HSE
Gone 4.2 supercharged RRS
Gone 90
Gone s2000
Post #600587 Sat Jun 20 2020 7:23pm
glenn9999
I paid cash but paid the deposit on card
Post #600605 Sun Jun 21 2020 6:21pm
glenn9999
so car has been to an indy this morning system was leak tested and result was no leaks
car had almost no gas in the system indy regassed and left for 2 hours running with no issues or leaks during this time
all in cost me £49.99
Post #600638 Mon Jun 22 2020 11:23am
Gibo993
perfect result. My freind runs a very busy garage and says most manufacturers only fill cars with enough gas to make the system function. So with RRs it can take 800g but will still work with 405g. They have tested new cars straight from the showroom and found this to be the case, sneaky eh!
Post #600708 Wed Jun 24 2020 7:26am
Gents, if the engine has been working hard, is it normal for the non-aircon air to be hot? Question --
Post #600713 Wed Jun 24 2020 8:09am
