![]() | Home > Technical > whats this levers function |
david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166 ![]() ![]() ![]() |
Think it’s the headlamp leveling sensor.
It controls the height of the suspension.
kenpassey Member Since: 03 May 2018 Location: Liverpool Posts: 33 ![]() ![]() ![]() |
Thanks Lads for the reply regarding the lever.. appreciated. As for my starter motor click, i swapped R6 Relay with a compatible one from the fuse box but it made no difference, i have still not located the earth point, yet i will remove the wheel tomorrow.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9051 ![]() ![]() ![]() |
The device in your photo is the ride height sensor for that wheel. The car uses it to determine the wheel's vertical position when changing the height from access to normal to off road heights amongst other things. 2012 SDV6 - it's missing a couple of cylinders
hairy Member Since: 02 Feb 2020 Location: aberdeen Posts: 31 ![]() ![]() ![]() |
I had exactly the same problem, had to replace the starter.... |
thanks, i think it will end up being replaced. cheers |
Just a quick question on the starter motor the large lead is the power.. is the smaller plastic connection to earth. Thanks |
The small wire requests the starter to turn.
