Home > Technical > whats this levers function
kenpassey
United Kingdom 2007 Range Rover Sport Supercharged HSE Java Black
what is this white levers function, located by the starter motor, i was looking for an earth location to clean up due to a dreaded click and no start on my 4.2 v8 s/c 2007 range rover sport, which without removing the inner wheel arch, i cant locate,
any ideas as to what this lever does. cheers
Post #600573 Sat Jun 20 2020 1:07pm
david007
United Kingdom 2011 Range Rover Sport SDV6 SE Vesuvius Orange
Think it’s the headlamp leveling sensor.
From google.
A headlamp levelling system adjusts the height of the cut-off line to the load condition of the vehicle. This is supposed to avoid blinding oncoming traffic when the vehicle is loaded
Post #600574 Sat Jun 20 2020 1:28pm
It controls the height of the suspension.
Change the relay under the bonnet marked SM
Post #600575 Sat Jun 20 2020 1:48pm
kenpassey
Thanks Lads for the reply regarding the lever.. appreciated. As for my starter motor click, i swapped R6 Relay with a compatible one from the fuse box but it made no difference, i have still not located the earth point, yet i will remove the wheel tomorrow.
on a side note i turned the ignition key maybe 7 times and the starter kicked in.. ive got a fully charged new battery, checked the battery earth lead and terminals - no corrosion and good contact. so its looking like maybe a solenoid problem, which i guess equals a new starter motor. but first of all ill clean up the earth contact point and try to get at the starter motor leads.
Thanks for the Tip.
Post #600576 Sat Jun 20 2020 2:59pm
The device in your photo is the ride height sensor for that wheel. The car uses it to determine the wheel's vertical position when changing the height from access to normal to off road heights amongst other things. 2012 SDV6 - it's missing a couple of cylinders
Post #600580 Sat Jun 20 2020 5:17pm
hairy
United Kingdom 2009 Range Rover Sport TDV8 HSE Zambezi Silver
Thanks for the Tip.
I had exactly the same problem, had to replace the starter....
Post #600594 Sun Jun 21 2020 6:08am
kenpassey
thanks, i think it will end up being replaced. cheers
Post #600601 Sun Jun 21 2020 11:33am
kenpassey
Just a quick question on the starter motor the large lead is the power.. is the smaller plastic connection to earth. Thanks
Post #600602 Sun Jun 21 2020 2:53pm
The small wire requests the starter to turn.
I usually get a large flat blade screwdriver
Ensure the car is in park.
And being careful not to touch earthed metal!
Bridge between the big red and the tiny request wire.
If the starter turns it’s ok.
You will get some sparking.
And loads of sparks if you get it wrong
Post #600603 Sun Jun 21 2020 3:53pm
