![]() | Home > General (L494) > Has anyone fitted a deployable towbar |
I haven’t fitted one but I’ve had my bumper off & it looks fairly easy to do & the wiring should be there.
You might also need this to operate the Towbar,it goes in the panel on the offside of the boot.
pc1972 Member Since: 30 Aug 2012 Location: scotland Posts: 38 ![]() ![]() |
Hi tyrefitter , yes is that the switch that’s goes in the boot?, also some of the ones for sale on eBay are just the deployable towbar and some have a sguare subframe that the towbar structure would attach to? I won’t be towing a caravan ,it’s just for my bike rack , I think I’ll need a electric module as well ?
I’m sure the square frame is for the full fat & not the sport,I haven’t seen the frame on mine but I will double check tomorrow.Ill also take a pick where the switch goes. Andy.
Thanks tyrefitter that would be great 👍 |
Riverblanche that looks slightly different as the L494 fastens to the rear panel not to the chassis like the disco & L320,the L494 hasn’t got the chassis.Ive been under mine loads of times with having my own lifts & ive never seen the square frame.
Hi riverblanche thanks I’ll have a look 👍 |
Ok thanks riverblanche👍 |
The L494 does have that square frame,it bolts inside the boot. Andy.
Thanks tyrefitter, do you know what LR mean by towing preparation, it was listed on mine but I’ve no towbar fitted ? |
Probably means wiring is there.I took a picture of the square frame & it fastens underneath where their is pre drilled holes in body.It goes round the battery case.
Hi tyrefitter I’ve looked under mine I’ve not got any box section 👎it has the predrilled holes so I’ll need to source that piece as well 🤔 |
